Hi all, I want to build a sequencer (much like the led sequencer circuits you find everywhere) which instead of lighting LEDs sends approx 12v to an electronic match (think of it as a 12v lamp - (which takes a lot more current to light than an e-match takes to fire!)).
I'd like up to 16ish channels, but less will do. I'd like to be able to control the speed of the sequence from start to finish (no repeat is nescessary!). A simply POT adjustment would do.
Finally, I'd like to trigger the sequence with a 12v pulse (push of a firing button from my main 12v firing system)
I've found this page...
and am looking at knocking up the 16 led sequencer with the added transistors for 12v support and then somehow knobbling the return sequence (shouldn't be har I guess).
I'm fairly good with BASIC electronics (I built my own firing system, and am fine with diodes, resistors etc and have used transistors and ICs but don't understand properly how they work).
Are there any example circuit diags out there I can look at?
p.s. I really want to make this as the comercial products start at about £800!!! as soon as you associate anything with professional pyro the price goes up by x10!
