Billy Mayo
But how does this tell you that the capacitor is leaky or not?
To test a cap for leakage you apply a voltage and measure the current. But the current could be low so you need a low current meter to be able to measure it.
You want to measure the current passing through the cap, with voltage difference between the cap´s terminals.
are you absolutely sure the problem is leakage? Could it be that the cap and the resistor don´t have spot on values?
although you need a volt meter that has high input impedance.
you have to be able to measure microamps, and also you have to be careful not to blow out the meter.
Leakage is the current passing where it should not, so more curent provided by the supply equals to more leakage Ideally the current should be zero meaning no leakage at all.
The voltage across the cap should be made the same so that you get comparable results. Vastly different voltage will produce vastly different leakage current.
The current meter should measure higher current when the capacitor is more leaky.
.Setting the voltage the same is just a way that allows you to accurately compare that current betweenthe different boards
for example connect the cap to an external supply. Then compare the currents measured.
The cap will charge to whatever voltage the supply has, regardless of leakage. You need to make sure that the supply voltage is the same in all measurements.
I don´t know how many times i have already said this. You want to measure the current passing through the capacitor when the voltage across it is X volts.So then how would you know if it's leaky or not? if the cap will charge to whatever the voltage the supply has
Time it takes it to charge depends mainly on the capacitance of the capacitor, and they have wide tolearnces so you would get meaningless results.You would have to use an oscilloscope to measure the TIME it takes the cap to charge to the external supply voltage it seems
