READING A PUSHBUTTON & display on LCD
Was thinking of the same, are you planning on using the application for a aquarium sump. If it works on water I wanted to try the same and use it to control the top off water for the sump.
Well i tested the sensor on some liquids(water, milk, oil and coke):) last night and its analog output voltage is similar to that of the datasheet...so it does work on liquids...il post the graphs when i get home...its on my desk top and im in uni at the moment....
Very nice. I love experimentation. Did you vary the depth of the liquid or just the distance from the liquid's surface? The experiment I would sugest is water in a deep bowl. Add about 3 to 4 cm of water and measure at 10 and 20 cm from the surface. Then increase depth of water 10 cm and repeat.
John
Edit: On reconsideration, make the initial water depth only 2 to 3 cm. Keep the rest the same.
I varied the distance, i will be back later-i will try out what you said when i get home jpanhalt, my lift club is leaving soon....got to go now
This was just a rough test i did with the GP2 and various liquids....
tomorrow i plan to do a more accurate test so each liquid will have the same type of container
  • comparison of all charts.doc
Yeah Atomsoft hehe im gonna try to:). Nyty nyt, its 23:04 here......take care
jpanhalt...i posted the new measurements on my GP2 sensor thread...if you want to take a look.......
Hello AtomSoft....this is the original code...i want to modify it slightly so that i can allow the user to ENTER 3 values(which i can use)....so my plan is to make a function out of the code i highlighted in red below....(that is the the part when the user presses enter)
i want to call that 3 different times so it does something like:
"enter height"
call enter/settings (which is now user input function in new code)
height=MyVal
"enter range"
call user_input
range=MyVal
"enter surface area"
call user_input
area=MyVal
well i just want to know if the way im assigning height=MyVal is correct in the new code below..............My val is determined in the user input stage...My Val is the number i need to manipulate...so am i assigning it correctly? or do i need to use a return MyVal then height=user_input() ???
old code:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(void);
void home_screen(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void main(void);
void calc_distance(void);
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
int height=50, SensorPos=10;
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4	//ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(2); //wait for LCD to be ready shorter delay
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
// These are my inits. Comment them out and use the above for you
	lcd_cmd(0x02);
	lcd_cmd(0x08);
	lcd_cmd(0x02);
	lcd_cmd(0x08);
	lcd_cmd(0x00);
	lcd_cmd(0x06);
	lcd_cmd(0x00);
	lcd_cmd(0x0E);
	lcd_cmd(0x00);
	lcd_cmd(0x01);
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	MyVal = 0; //initializn these variables here
	MyMinVal = 0;
	MyMaxVal = 99;
    OSCCON|=0x60; //set fosc to 4Mhz
	TRISB=0x00;
	TRISC=0xFC;
    TRISA = 0b10010010; 	// RA7 high imp, RA3 is serial out, RA4 button input
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
	lcd_init(); //call LCD initialisation
char WaitForInput(void){
char done;
char temp;
done = 0;
while(!done){
    if(!ENTERSETTINGS_SW){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    DelayMs(150);    //debounce
    return temp;
void EnterScreen(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER/SETTINGS ");
void ShowDigits(unsigned char val){
    MyValLCD[0] = val /10;    //returns the quotient (if temp = 35 the result is 3)
    MyValLCD[1] = val % 10; 	//Returns remainder   (if temp = 35 the result is 5)
	MyValLCD[0] += 0x30;	//to ASCII
	MyValLCD[1] += 0x30;	//to ASCII
	EnterScreen();
	lcd_goto_L2();
	lcd_data(MyValLCD[0]);	//to LCD
	lcd_data(MyValLCD[1]);  //to LCD
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
void home_screen(void){
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
  // i dont have a while(1) here any more
//Im calling the wait for input function here
input_sw = WaitForInput();
	while(input_sw != 1);  // wait until enter is pressed
	EnterScreen();
	mnuPOS = 1;
	DelayMs(2);				//shorter delay
	[COLOR="Red"]while(mnuPOS == 1){
      switch(input_sw){
		case 1:
			mnuPOS = 2; //This tells us the user finished entering
			lcd_goto_L1();
			lcd_puts("     Done!      "); //home screen message (line 1)
			break;
      	case 3:
			if(MyVal < MyMaxVal)
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
			if(MyVal > MyMinVal)
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	//Do something here with the new Value which is a decimal in
	//MyVal. The user is here because all data is entered
	//i added a return here
    //return;
	//im not 100% sure but since its a void i think a return isnt needed[/COLOR]
void main(void)
 init();	// initialise I/O ports, LCD
 while(1){
 	home_screen();
here is the new code.....................
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
void user_input(void);
void EnterHeight(void);
void main(void);
void init(void)
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
void EnterHeight(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER HEIGHT ");
	lcd_goto_L2();
	lcd_puts("Press UP/Down"); //home screen message (line 2)
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	while(mnuPOS == 1){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	EnterScreen();
	EnterHeight();
	mnuPOS = 1;
    user_input();
	[B][COLOR="Blue"]height=MyVal;[/COLOR][/B]
void main(void)
 while(1){
 	home_screen();
Try this :
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
unsigned char user_input(void);
void main(void);
void init(void)
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_puts("Press Up/Down"); //home screen message (line 2)
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
 //[b]
unsigned char user_input(void)		//This will return what we want[/b]
	char done = 0;
	MyVal = 0;			//[b]Start on 0[/b]
	while(done == 0){
      switch(input_sw){
		case 1:
			done = 0xff; 			//This tells us the user finished entering
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	input_sw = 0;			//Reset the value
	while(input_sw != 1)  	//Wait until enter is pressed
	EnterScreen();
	EnterHeight();
	DelayMs(2);				//shorter delay [b]
    height = user_input();	//The HEIGHT var will have the myVal[/b]
void main(void)
 while(1){
 	home_screen();
EDIT: What happened to all the variable declarations?
b4 when i was playing around & trying my own tricks...it did get stuck in the while loop
Hey...i am at uni.....when i get home...i will test it out n let you know what happens.........................
OOOpZ......Cut n paste
Hello AtomSoft.....i tried the code and.....as soon as i power up it displays....
"IR LLD:)"
enter height
press up/down
done!
press up/down
" IR LLD"............and it loops the same sequence above....
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
void main(void);
char temp[8];
unsigned char height=50, SensorPos=10;
char input_sw;
char mnuPOS;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	MyVal = 0;			//Start on 0
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	EnterScreen();
	EnterHeight();
void main(void)
 while(1){
 	home_screen();
ZzzzzzzzZZZZZzzzzzzzzzzzzzzzzzzzzz...im so tired, was doing my pre-prac for tomorrow...sorry for the late response...
Here you go complete:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>	//[b]
void userMenu(char pos); //[/b]
void init(void);
void main(void);
char temp[8];
//[/b]
unsigned char height=50;
unsigned char range;
unsigned char area;
unsigned char SensorPos=10;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
}//[b]
void userMenu(char pos){
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			lcd_puts("    HEIGHT    ");
			break;
		case 1:
			lcd_puts("    RANGE     ");
			break;
		case 2:
			lcd_puts(" SURFACE AREA ");
			break;
	lcd_goto_L2();
//[/b] New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	//EnterScreen();
	//EnterHeight();
	userMenu(0);
	userMenu(1);
    range = user_input();	//The HEIGHT var will have the myVal
	userMenu(2);
    area = user_input();	//The HEIGHT var will have the myVal
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
void main(void)
 while(1){
 	home_screen();
well its doing the above stuff without me pressing any buttons....
o gosh i just looked at mplab config bits again.....i had saved this in a new file and it reset the config bits to default.....:rolleyes:
im sure it will work after i set the bits correctly again.....thanx AtomSoft.....
lol:) complete :rolleyes: thanx ;):p:)....
Yeah it sure is working smoothly...:)tried it out now....
i have to start paying forward my bank balance (im not working yet lol)...if i dont start paying back in kind hehe....
