READING A PUSHBUTTON & display on LCD
Try this as your usermenu stuff. The slow speed might be because of that 2 second delay you have in the menu using timer1:
void userMenu(char pos){
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			lcd_puts("    HEIGHT    ");
			break;
		case 1:
			lcd_puts("    RANGE     ");
			break;
		case 2:
			lcd_puts(" SURFACE AREA ");
			break;							//
		case 3:
			lcd_puts("   MEASURED   ");
			 while(WaitForInput(1) != 2){		//Wait for user to press enter to leave loop
 				// wait for 2 seconds, uses TMR1 free running at 1Mhz
   				while(!TMR1IF)  		// wait for TMR1 overflow
				TMR1IF = 0; 			// clear overflow flag
				bres += 65536;			// add 65536uS to bres value
				if(bres >= 2000000)		// if reached 2 seconds!
    				bres -= 2000000;	// subtract 2 seconds, keep error
					// read the ADC voltage RA1 (Sharp GP2 sensor)
					GODONE=1;					// initiate conversion on the channel 0
					while(GODONE) continue;  	// Wait convertion done
					calc_distance();			// convert ADC value to distance
					lcd_goto_L2();				//Only change line 2
					lcd_data(cm10 + '0');
					lcd_data(cm + '0');
	    			lcd_puts(" [cm] ");			//comment this out if you want
		lcd_goto_L1();
		lcd_puts("      OK      ");
		lcd_goto_L2();
		lcd_puts("              ");
		break;
	if(pos == 3) return;
	lcd_goto_L2();
	lcd_puts("Press Up/Down"); //home screen message (line 2)
Holding Home down will take you home.
EDIT: If you can read this try the code again. I edited it/
Ok ok i forgot a few things. try this full code:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>	//
void userMenu(char pos); //
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(char expire);
unsigned char user_input(void);
void home_screen(void);
void EnterHeight(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void calc_distance(void);
void main(void);
unsigned char cm2LCD;
unsigned char cmHigh, cmLow;
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned int LiquidLevel;
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
//char temp[8];
//[/b]
unsigned char height=50;
unsigned char range;
unsigned char area;
unsigned char SensorPos=10;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
unsigned long bres;		// for bresenham 2-second timer system
unsigned char ;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4	//ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(2); //wait for LCD to be ready shorter delay
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x02);
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	// setup the PIC 16f690
	OSCCON = 0x72;      	// internal osc, 8MHz
	PORTA = 0;
	TRISA = 0b10010010; 	// RA7 high imp, RA3 is serial out, RA4 button input
 	PORTB = 0;          	// PORTB not used
    WPUB = 1;				// PORTB pullups ON
    RABPU = 0;
    /* Init ADC */
    ADCON0 = 0b10000101;	// bit 7 right justify,analogue channel select bits bits5-2  0001=AN1,ADC ON, RA1 is ADC input
	ADCON1 = 0b00100000;	//bits6-4  fosc/32
    ADON=1;	                // turn on the A2D conversion module
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
    T1CON = 0b00010001;     // TMR1 is ON, 1:2 prescale, =1MHz
	T2CON = 0b00000101;     // TMR2 is ON, 1:4 prescale, =1MHz
	MyVal = 0; //initializn these variables here
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	lcd_init(); //call LCD initialisation
//EDITED this a bit. now if expire input is set it will leave loop with a 0
//instead of rechecking this will be useful for display your measured data and
//waiting for user to exit.
char WaitForInput(char expire){
char done;
char temp;
done = 0;
temp = 0;
while(!done){
    if(!ENTERSETTINGS_SW){
		while(ENTERSETTINGS_SW);
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
	if(expire == 1) break;
}//end of while
    DelayMs(150);    //debounce
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
					lcd_data(cm + '0');
		lcd_goto_L1();
		lcd_puts("      OK      ");
		lcd_goto_L2();
		lcd_puts("              ");
		break;
	lcd_goto_L2();
// New Menu System
void EnterHeight(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER HEIGHT ");
	lcd_goto_L2();
void EnterScreen(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
void ShowDigits(unsigned char val){
    MyValLCD[0] = val /10;    //returns the quotient (if temp = 35 the result is 3)
    MyValLCD[1] = val % 10; 	//Returns remainder   (if temp = 35 the result is 5)
	MyValLCD[0] += 0x30;	//to ASCII
	MyValLCD[1] += 0x30;	//to ASCII
	EnterScreen();
	lcd_goto_L2();
	lcd_data(MyValLCD[0]);	//to LCD
	lcd_data(MyValLCD[1]);  //to LCD
unsigned int mathKeep;		// [b]used for voltage calculations backup[/b]
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	//[b]Create a copy of math for more use[/b]
	mathKeep = math;
    //LiquidLevel=height-;
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	math = mathKeep;	//[b]Now our original data is back and can be used.[/b]
unsigned char user_input(void)		//This will return what we want
	char done = 0;
	MyVal = 0;			//Start on 0
	while(done == 0){
   	  input_sw = WaitForInput(0);
      switch(input_sw){
		case 1:
			done = 0xff; 			//This tells us the user finished entering
			lcd_goto_L1();
			lcd_puts("      OK       "); //home screen message (line 1)
			break;
      	case 3:
			if(MyVal < MyMaxVal)
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
			if(MyVal > MyMinVal)
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
void home_screen(void){
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
	input_sw = 0;			//Reset the value
	while(input_sw != 1)  	//Wait until enter is pressed
	userMenu(0);
	DelayMs(2);				//shorter delay
    height = user_input();	//The HEIGHT var will have the myVal
	userMenu(1);
    range = user_input();	//The HEIGHT var will have the myVal
	userMenu(2);
    area = user_input();	//The HEIGHT var will have the myVal
	userMenu(3);
//Waits for user to press ENTER to show home screen
"enter height"
call enter/settings (which is now user input function in new code)
height=MyVal
"enter range"
call user_input
range=MyVal
"enter surface area"
call user_input
area=MyVal
/*  Junebug_Serial4.c    RomanBlack.com 19th July 2009.
    uses "zero error 1 second timer"
	system to generate a 2 second interval, then every
	2 seconds it reads an analog voltage from a
	Sharp GP2 distance sensor and converts it to decimal
	distance, then sends that data to a LCD
	Code for MikroC, config handled by MikroC compiler;
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    init();	// initialise I/O ports, LCD
    while(1){
 	home_screen();
 /*// wait for 2 seconds, uses TMR1 free running at 1Mhz
	//	LiquidLevel=height-;
	//	lcd_clear();                // Using the new menu you can erase or
	//	lcd_data(cm10 + '0');
	//	lcd_data(cm + '0');
	 //   lcd_goto_L2();
	   // lcd_puts("[cm] ");			//comment this out if you want
This code checks 4 times a second
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
				if(bres >= 250000)		// if reached 2 seconds!
    				bres -= 250000;	// subtract 2 seconds, keep error
					lcd_data(cm + '0');
		lcd_goto_L1();
		lcd_puts(" Loading Home ");
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
lol OK Super Cool:) That fixes the get to home screen problem hehehe but it comes with a price.....
the sensors reading slow.....
Loading Home:)
It got a bit faster.....R u changing the oscillator frequency???
It needs to be pretty fast to detect the changes in the level of the liquid
MATHKEEP:rolleyes: Ok thats a better solution by far...lol dont know why my thinking is so complicated hehehe maybe coz im a gal :D
unsigned char LLHigh, LLLow;
unsigned int mathKeep;		// used for voltage calculations backup
	math = ADRESH;
	math += ADRESL;
	//Create a copy of math for more use
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	math = mathKeep;	//Now our original data is back and can be used.
	[COLOR="Plum"]do i need to say height=user_input???[/COLOR]
      [COLOR="Red"]LiquidLevel=height-math;
      //LiquidLevel is higher than 09 so spilt the variable LiquidLevel into 2 //
      LLHigh = ( LiquidLevel / 10 ) + '0'; //
      LLLow = ( LiquidLevel % 10 ) + '0';  // [/COLOR]
LOL it workzzzzzzzzzzzzzzzzzzzzzzzz!!!!!!
it displays the height-liquid level
I only made the changes in RED highlight..................
I entered the height as 70cm
i put a paper 10cm away from the sensor...
& it says measured 60cm
:):):):):):):):):D:D:D:D:D:D
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
[COLOR="Red"][B]
					lcd_data(LLHigh + '0');
					lcd_data(LLLow + '0');
	    			lcd_puts(" [cm] ");			//comment this out if you want[/B][/COLOR]
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	[B][COLOR="Red"]LiquidLevel=height-math;
      LLLow = ( LiquidLevel % 10 ) + '0';  // [/COLOR][/B]
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
Hehe...just applying YOUR tricks there AtomSoft......................................:)
Fast learner lol i hope i am...........THANX THANX THANX AtomSoft 4 President!!!
Uhmmmmm but i still got to work on speeding it up.....(i am goin to do that now)
OMG!!!! i dont know what happened now.....i reloaded the exact code from above(the one i made changes to...the one that was working) but!!!
the measured "values" are ALPHABETS!!!!:eek: now
Ok there it is..... Shew!!!!working again BUT i noticed that.....it does still display measurements as ALPHABETS but this happens in acertain case.....:
CASE 1[negative case]
Eg if height=30
distance away from sensor=40
liquid level will thus be=-10 BUT we dont have negative distances....
*(uhmmmm i declared LiquidLevel as unsigned int)
AND thats when it displays all funny kind alien like wingding symbols hehehe...:eek:
CASE 2 [positive case]
But if height=30
distance away from sensor=10
lcd displays measuerd distance=20cm:)
So basically the negative case(liquid level is higher than the container-maybe an overflow) is like an impossible situation in which case it would be appropriate to display a suitable message if the distance is negative???
Uhmmm but also i should consider displaying a message if the container is full
ie. container height=liquid level
Well i want to know what can i do to prevent those funny symbols from appearing????
& how can i speed up the sensor....i tried in vein hehe
ADCON2 = 0b10100010; // right justify, 8Tad, 32Tosc would increasing the32Tosc help?
O the speed all deals with the timer?
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
				    lcd_data(LLHigh);
    		 	    lcd_data(LLLow);
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
no :D if you take out that delay or make it less then its faster:
    unsigned int delaytime = 100000; // 100ms [COLOR=RED][b]CHANGE THIS FOR YOUR BELOW DELAY[/b] [/COLOR]
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
				bres += 65536;			// add 65536uS to bres value[b][COLOR="Red"]
				if(bres >= delaytime )		// if reached 2 seconds!
    				bres -= delaytime ;	// subtract 2 seconds, keep error [/COLOR][/b]
					lcd_data(cm + '0');
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
Yeah thats cool
Maybe i should say something like :
1)if liquid level<0 [ie. negative]
[this would happen for an over flow ie .when the level of the liquid is > height of container]
then--> lcd display "ERROR"
in this way it would prevent funny symbols from being displayed...........
AND all negative distances will be represented by "error"
2)if liquid level=height then--> lcd display "FULL"
3)if liqud level level=00 then--> lcd display "EMPTY"
so these 3 cases cater for all 3 scenarios that can take place.....
sounds good???
The speed is much much better now-:)only changed the part in RED.....hope im displaying it correctly to LCD. The alien wingdings appear when the level is negative otherwise it displays positive values correctly
[COLOR="Red"][B]	lcd_goto_L2();				//Only change line 2
					lcd_data(LLHigh);
					lcd_data(LLLow);
	    			lcd_puts(" [cm] ");			//comment this [/B][/COLOR]out if you want
here the code with the red highlight included:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
    unsigned int delaytime = 100000; // 100ms CHANGE THIS FOR YOUR BELOW DELAY
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
					lcd_data(LLHigh);
					lcd_data(LLLow);
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
I didnt use this below to display
	//	lcd_data(LLLow + '0');
because the LCD displays ALPHABET measurements
EG
Measured
ae
Try this it will show 00cm if its a Negative:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
					lcd_data(LLHigh);
					lcd_data(LLLow);
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	[b][color=red]//This will check if negative
        if((LiquidLevel < 0) || (LiquidLevel > 0xFFB0))
		LiquidLevel = 0;
	//if below zero which will be in the 0xFFFF range i just chose any 0xFFxx number :D[/color][/b]
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
The usual way to handle negative numbers is by doing something like,
    if(value<0){        //if negative
        value=-value;   //negate it
        LcdPut('-')     //print minus character
    }else{              //if positive
        LcdPut(' ')     //print space to keep allignment
As you are doing the calcs in a function, you could set a flag in you code when you negate it.
ok i will try the code....Thanx AtomSoft....
Tried it & it works:):):):):):):)....
*i will also write some code for calculating the volume of the liquid in the container....
surface area X level of liquid
Now later today im going to test this "IR LLD" on LIQUIDS:D:D:D How exciting lol....................I hope it works accurately.....
For now im going to start learning for my exams:eek:
ok i will try the code....Thanx Atom....
bt i think it should only display 00cm when its empty:rolleyes:
i think "error/overflow" is more suitable for the negative case:p
Morning Miss f,
IMO 'error/overflow' is misleading, sounds as though the 'tank' is over full.:)
Pommie's method is often used to indicate less than zero values.
