I have a brushed DC motor which operates from 0-40VDC. It gets a supply signal from a motor controller. There is also a tachometer output from the motor (0-40VDC as well) which gets fed back into the motor controller.
I need to have a reading of the the motor supply voltage and tach voltage fed into a computer DAQ system. The DAQ system I'm using has a 0-10VDC analog input.
My question is: How do I signal condition The motor supply and the tach output to be properly read by the DAQ system?
Thanks in advance!
Thanks in advance!
