RGB LED strip - 90 degree connectors?
Hippogriff
Hi all,
Just a quick message to enquire as to whether anyone on here has ever found any right-angle connectors for sale so you can plug RGB LED strips together, but without the extra LEDs, just the connector? If possible, I would like to avoid extra soldering. I've seen the following:
10MM Strip to Strip LED connector (for SMD 5050-150LEDs series) [HK-STSC-10MM] - £0.48 : LEDLIGHTSWORLD.CO.UK
Which connects two strips together, but in the same direction.
And I've seen:
Which is a very long (15cm) flexible connector and I'm just wondering if there is a simple, wireless, fixed right-angle connector out there that Google hasn't yet helped me find.
Most of them appear to be like the following elbow connectors, i.e. with extra LEDs on them...
What I ideally want is just like a simple elbow, without LEDs... am I missing something?
No, I didn't find these. I enquired with a few companies who said they would make me connectors that had two connecting ends separated by a short enough run of 4 wires, but they wanted quite a bit of money for each one, so I ended up doing it the way I wanted to avoid - soldering straight onto the RGB strip pads.
