Time will tellis it going to be enough ?
Time will tell.
You will need bigger batteries than 5Ah if you want more than a few minutes running time.
If I were building this I would assume the average motor current would be ~20A, which means the 7Ah battery would be completely flattened in 7/20h = 20mins. You don't want to run a battery completely flat or you'll kill it. So 7Ah would not be enough for 12-15 mins in my opinion.
BTW, are you aware the gyro effect of that flywheel will be huge and make the robot impossible to steer unless the flywheel axis is vertical?
