summitville
Nomad-In-Exile, If you use a 40 Watt Solar Panel at 90% efficiency with a Xantrex Inverter at 90% efficiency to recharge AA NiCd Batteries at 90% efficiency (those are absolute BEST conditions by the way) that will give you enough power recharge just 6 @ AA 3000mah NiCd Batteries in 1 hour.
Now, you say you need to recharge ...
A) Video Camera batteries (used 2-3 hours nightly - how many & what size batteries?)
B) Digital Camera batteries (100-200 photos nightly - how many & what size batteries?)
C) Laptop batteries (used 1 hour per day, 30 watts ?)
D) Black Light batteries (used 2-3 hours nightly - 3 @ AA NiCd)
E) Cell Phone battery (used 30 minutes/day - 2 Watts - insignificant)
Your plan is to recharge all batteries each day / every day in 4 hours from 10:00AM - 2:00PM?
Can you currently recharge the ...
A) Video Camera batteries in 1 hour using a ~30 Watt charger?
B) Digital Camera batteries in 1 hour using a ~30 Watt charger?
C) Laptop Battery in 1 hour using a ~30 Watt charger - (most likely) YES!
D) Blacklight flashlight (3@AA) batteries in 30 minutes using a ~30 Watt charger - YES!
E) Cell phone in 30 minutes using a 2 Watt charger - YES!
There is your entire 4 Hour Charging Window - nothing else needs recharged?
So, if you answer "YES" to A & B then a 40 Watt Solar Panel might just work.
Just be carefull using the Xantrex 400 because fully loaded (320W) it can can drain that 10AH Battery in just 20 minutes!
Then it will take you 6 Hours the next day just to recharge your main 10AH Battery.
You must keep your Xantrex Power draw lower (on avg) than the power the Solar Panel can deliver.
With a single 30 Watt Battery Charger / AC Adapter connected, I think the Solar Panel can "keep up".
Also, make sure all of your Battery Chargers / AC Adapters work properly (no overheating, etc)
with the Modified Sine Wave AC output of the Xantrex Inverter BEFORE you leave for your trip.
Always shut-off the Xantrex inverter when not in use.
You must make sure everything gets fully charged by 2:00PM, daily.
Do you have a spare battery pack for each device?
A 40 Watt Solar Panel may be do-able.
The last thing you need is a dead Video Camera, dead Digital Camera, dead Computer or dead UV Flashight.
Heck, you could Dry-Run at home to make sure 4 Hours of "Charge Time" is enough for everything.
If you have the time and the sun I would recharge everything fully every day.
You never know what tomorrow may bring.
You mentioned conencting to an Internet Website (Blog?) and Email.
How are you connecting to the Internet during the trip?
