The PIC16C5X Series can be programmed by applying
the 12-bit wide data word to the 12 available I/O pins
while the address is generated by the on-chip Program
Counter. The MCLR/VPP pin provides the programming
supply voltage (VPP). Programming/verify chip enable
is controlled by the T0CKI pin while the OSC1 pin controls
the Program Counter.
csaba911 said:PIC16C57 is not the same family as PIC16F5x :!:
TiagoSilva said:Hi, are those stollen :lol: ?
mysemcon2000 said:We have an overstock in our inventory of PIC16F877A and PIC16F876A, pm me if you are interested 10 and above quantities.
bluex_scf said:The Pic16C57 is not serially programmable. It's an old generation of Pics MCUs. It has no Timers, only One interrupt source, and is OTP. The very limited resources on this pic makes it quazi-impossible to do usefull developments on it using a compiler. Most of the compilers on the market (Basic, C, Pascal ....) do not support this chip and some times PARTIALLY supports it. The problem is that this chip is a 12 bit core, its like the 12c50x family, it's not a 14bits core (like the 16c84). The only way to do something usefull with this mcu is to use asm.
PS. This
blueroomelectronics said:It's an old thread but I couldn't help myself. The BASIC Stamps use the 16C57
