BryWY,
In your post #67 you have not got the connections quite right. I am assuming that you have bought a straight through (Pin 1 to pin 1, pin 2 to pin 2 and so on.) 9 pin male to 9 pin female cable and that you have cut the cable. I also assume that you are joining the wires is chock block (Screw connector strip or whatever you call it in your county.) You should have pins 1, 4, & 6 at the PC (Female) end joined to pins 1 & 6 at the plotter (Male) end. So brown, yellow and blue from the PC end should ALL be connected together an be connected to brown and blue from the plotter end. (You need to connect the blue wire from the PC end to this terminal on the terminal on the connector strip. (So there will be 5 wires joined together.) I think that your problem now is that without handshaking the PC is sending data faster than the plotter can handle. I suggest that you connect the blue wire from the PC end and set the flow control back to the way it was and see if that solves the problem. If you post the flow control options that you have to choose from and tell us how it was set when it worked with the original cable we may be able to work out what is wrong rather than just guessing.
Les.
Les.
