Confession - I do not know what I am doing but the best way to learn is to jump in and build something
I've purchased this board - **broken link removed**
A breif description of the sensors is here - Theory of Operation - Paparazzi
I'm using this board to control a rocket motor mounted to a gimbal and make it fly straight up.
As near as I can tell the sensors are shorted out for lack of a better description. I supply the sensors with 3.3 volts in; easy enough I can wire that up. The sensors (I am guessing) provide differential resistance based on temperature readings.
I then get a variable voltage out somewhere between 0 and 3.3 volts with 1.65 volts telling me that the sensors have an identical temperature reading.
Thus, 0V - 1.64V would mean I need to actuate a servo to the right and 1.66V - 3.3V would mean I actuate the servo to the left.
I do have a small flight computer which I could use to monitor the voltage and run a program to actuate a servo but... I think this will be far to slow to control a rocket motor.
I believe a circuit could do the same thing. If I could create one that activates a switch based on the voltages described then I would get the response time I need and it would be far more simplistic. I suppose that might mean I need 2 circuits for each of the two servos.
I have no idea how to build this other than I probably need a comparator.
Help?? Suggestions??
Thanks!
Thanks!
