I am a real amateur when it comes to all things electronics and I was wondering if you could help me.
I have purchased land out in the middle of no where and have no power. Unfortunately I have had a fair share of red necks helping them selves to things on my property, or just simply snooping around when I'm not there.
Due to this, I have recently purchased a digital camera that runs off a 9volt battery. It takes a photo when motion is detected with the inbuilt motion sensor, and saves the image on to an SD card. Works an absolute treat for my intentions. However, the 9volt battery only has a life span of about 7 hours.
You might have a good laugh at this, but in my ignorance and attempt to have this set up on a continuous feed (i need it to run for 1 month inbetween visits). My attempt was in vain, you see what i set up was wires running from the camera to a rechargeable 9volt battery, from this battery i ran wires to a 12volt car battery and from the car battery i ran a 5watt solar panel that trickle feed the car battery.
I returned only to find the 9volt battery absolutely fried and the camera not working. At first thoughts i presumed i had fried the camera as well, however, after testing, it worked fine.
I discovered that feeding 12 volts direclty into a 9 volt battery probably isnt the smartest idea and have since been searching the internet for another idea.
What I am considering doing now is to hook my solar panel (5 watt) to the car battery (12 volt) and then running wires to a dc/dc converter that will reduce the feed simply to 9volts that i can wire straight into the camera.
Do you think this will work?
If not, can you please tell me the best possible way of achieving my outcome.
Thanks for your time,
here are the specifications of the camera should you need them;
Imaging Sensor: 1/ 4" Color CMOS sensor
Lens: F2.0/f3.6(4G+IR) pinhole
Resolution: 640H x 480V (4:3)
Responsively: 1.9V/lux-sec(550nm)
Dynamic Range: 60dB
S/N Ratio: 45dB
White Balance: Automatic
Exposure: Automatic
USB: 30 frames per-second
Power Supply: 8~14VDC
Current Consumption: Standby@12V~50mA
Max.(Alarm)@12V~50mA
Operating Temperature: 14°F ~140°F / -10°C ~ 60°C
Fire Protection: ABS plastic housing
Dynamic Range: 60dB
S/N Ratio: 45dB
Exposure: Automatic
