throbscottle
I think you must have a soldering iron fairy AG, that keeps your iron nice when you are not looking
A moment ago I looked at the cold tip of my soldering iron and it has dried rosin on it. When it heats then I will use my "fairy" to clean it:I think you must have a soldering iron fairy AG, that keeps your iron nice when you are not looking
One quick wipe on my damp grooved sponge before making my next solder joint.
The tip is a few years old and is used almost every day. It came tinned from the factory and I have never needed to re-tin it.
You know what? The tip of my soldering iron "accidently" gets re-tined when I tin the twisted together strands of stranded wire.
I used a propane torch, a tub of flux and lead-free solder to replace the water taps at my son's house. I never soldered copper water pipes before but they work perfectly and look perfect.
I got my bathroom renovated with an acrylic tub and walls. The real plumbers made a mess of soldering the taps and shower head because the joints leaked water 3 times, the 4th time they were soldered it doesn't leak anymore. I am not a plumber but I should have soldered them myself. Then they sent a handyman to repair the damaged ceiling underneath. Never mind.
