Hi all!
I'm new here! Just stumbled upon this forum
I'm trying to learn about solenoids. The reason is that heard about taking a
solenoid and removing windings to increase force. This sounds unsure to me, let
me try an example:
Let's say we have a solenoid of 10ohm and 25V. Using Ohms Law
we would get 25 / 10 = 2.5A. If we then remove windings and get 9ohm, then 25 / 9 = 2.8A.
That makes sense, as numbers, but does it really apply to solenoids? I mean, removing
windings can only go so far before resistance is zero, so the coil should be the strongest
when there's nothing left
What do you think of removing turns to make the solenoid
stronger? Does that work?
So I tried to find other answers, and found this:
B = Uo * (NI/l)
Example:
B = 1.257*10^-6 * (750 * 2.1A / 0,8M) = 2.5 mT
But this also confuses me. If I increase the windings to 1500, I double the B...the same
with ampere, and lowering l
But if I double the windings doesn't that double the resistance? or is it 'understood'
that that means also increasing the diameter of the wire? or does the resistance not
matter?
Thanks for your time!!
me try an example:
B = Uo * (NI/l)
Example:
matter?
