(Solved)Again problem with matrix, this time 8x32
ohya, looking back at post 9, you wanted to do a counter not a clock, but you want the counter to scroll correct?
That counter was just for testing purposes, but we can of course test that too with this code structure, scrolling was the main issue :).
okay! well im working on the font map & a scroll function,
is there anything we want to do specific in the main?
Well, for now any scrolling text would be enough, nothing fancy is needed at main, at least I can't think of anything.
k try this! plus another fontmap!
int dataPin = 2; // ic: 14, ser_in Define which pins will be used for the Shift Register control
int latchPin = 3; // ic:12 silkscreen numbers!
int clockPin = 4;
unsigned char displayPointer=0; // for interrupt use...
unsigned char buffer1[32]; // buffer for screen
unsigned char backbuffer[32]; // Spare screen for drawing on
unsigned char power[8]={128,64,32,16,8,4,2,1};
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine
if(TIFR2) // Make sure its the timer interrupt.
setcolumn(displayPointer);
setdata(buffer1[displayPointer]);
digitalWrite(latchPin ,HIGH);digitalWrite(latchPin , LOW ); // STORECLOCK
if(++displayPointer==32) { displayPointer = 0; } // 32 LED row sections in total
TIFR2 = 0; // Clear timer 2 interrupt flag
void setcolumn(unsigned char col){
signed char pos;
for (pos = 32;pos>-1;pos--){
if (col == pos){digitalWrite(dataPin ,HIGH);}else {digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
digitalWrite(clockPin ,HIGH);digitalWrite(clockPin ,LOW);
void setdata(unsigned char dat){
unsigned char pos;
for (pos = 0;pos<8;pos++){
if (dat & 128){dat-=128;digitalWrite(dataPin ,HIGH);}else { digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
dat = dat * 2;
void clr() //clear
int addr;
for(addr=0;addr<32;addr++) // Empty display buffer
backbuffer[addr]= 0;
void Blit() //transfers data between display buffer to screen buffer
int addr=0;
noInterrupts(); // disable all interrupts during setup
for(addr=0;addr < 32;addr ++)
buffer1[addr] = backbuffer[addr]; // put all data from display buffer
} // to screen buffer
interrupts(); // enable all interrupts
void pixel(signed char x,signed char y,int cond)
unsigned char pix,msk;
if(x<0 || y<0) return; // outside drawing limits negative
if(x>31 || y>7) return; // outside drawing limits positive
pix = power[y];
msk = backbuffer[x]; // get exsisting data
if(cond == 2)
pix ^= msk; // XOR data to screen
if (cond == 1)
pix = ~pix;
pix &= msk; // AND data to screen
if(cond == 0)
pix |= msk; // OR data to screen
backbuffer[x] = pix; // apply changes
void charput(unsigned char ch, signed char x,signed char y)
signed char x1, y1;
unsigned char disp;
unsigned char disp2;
for( x1=0;x1<8;x1++) // eight rows
disp = font[x1+(ch * 8)];
for (y1 = 0; y1<8; y1++) // eight pixels
disp2 = disp & power[y1];
if(disp2 > 0)
pixel(x+x1,y+y1,0); // OR the pixel to the display buffer
void strput(const char* ch, signed char x,signed char y)
int addr;
while (*ch )
charput(*ch++,x,y); // write a string to the display buffer
x+=7;
void setup() //setup runs once
signed char cntr;
DDRD = DDRD | B11111100; //port registers used to set pin directions
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 5; // compare match register 16MHz/256/2Hz -----------------------------------> delay time (lcd flicker/brightness)
TCCR1B |= (1 << WGM12); // CTC mode, free-running, clear on match
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
} // End main
void loop() //just sitting here
signed char scrollctr;
unsigned char numCTR;
clr();
strput("WOOF",0,0);
blit();
Delay(500);
for (scrollctr=-8;scrollctr<9;scrollctr++)
clr();
strput("WOOF",0,scrollctr);
blit();
Delay(200);
for (scrollctr=-32;scrollctr<33;scrollctr++)
clr();
strput("WOOF",scrollctr,0);
blit();
Delay(200);
for (numCTR=0;numCTR<10;numCTR++){
clr();
charput(numCTR,24,scrollctr);
blit();
Delay(200);
  • FontMap.h
Funny, I get lost with all these maps around...
just delete the old ones..... we have history here in forum, really you can just open it and cut and paste, then throw it away.
Hehe, about code, there were couple small typos, after fixing them, screen displays ''WOOF'', which disappears, and then slowly scroll from down to up, all the way until it can't be seen anymore.
I have feeling this was as intended?
wait! it also scrolls from left to right! :)
and after that, rightmost matrix displays 0-9 counter, flowing down to up!
also we should be mostly done with the fontmap, I populated all the numbers and the important letters:), so that should be it..... haha... if you need more letters , i will let you populate them!
also idk if i mentioned that blocks 0-9 are used for numbers, and Ascii symbols start at 32, so blocks 10-31 are free for you if you want to do custom characters.....
here is software i designed on visual studio 2012, custom to your display, you can use if you want, I put exe for those who dont care in publish.zip, but added source code too for those who do, in display_font.zip!
  • FontMap.zip
yup!
YUP! :) ......post vid pls! also post fixed code pls!
so in the main, you can see the 3 examples of how i did it, are you good from there? anything else we want to do/add?
sorry for delay, had paracord kechain to be made (handy while thinking stuff like codes , once it comes automatic routine)
Here's full code, I can also post video but I have feeling that takes long time to upload, then again, I'm in no rush.
Gotta take some time to understand that code hehe.
perhaps next thing would be to implement RTC or similar data to show, so matrix would have some purpose
I edited delay() values for it to scroll faster, helped bit.
C:
#include "FontMap.h"
int clockPin = 4;
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
unsigned char disp;
if(disp2 > 0)
int addr;
while (*ch )
x+=7;
signed char cntr;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
clr();
strput("WOOF",0,0);
Blit();
delay(5);
clr();
Blit();
delay(5);
clr();
Blit();
delay(5);
clr();
Blit();
delay(5);
yes, whatever looks best, also feel free to adjust this value:
too fast will over dim the leds, too slow will cause flickering
the main functions to understand are: pixel, charput, strput
pixel(x,y,c) where x and y are the position on map, and c is how we operate it in, not really sure what the 1 & 2 values will do! but this function will prolly be used least.
charput(s,x,y) again x,y is the start point and s is the character loaded from fontmap.....
strput("",x,y) same here, x,y is startpoint, and "" is the string that will be written in.
from there we are able to scroll using a for loop that changes the y value 1 by 1.
to get a RTC going it may be easier to setup another interrupt.
Should the interrupt be external (with square wave from RTC chip, 1hz) or another timer interrupt? I use those i2c RTC's
if it works, I'v never used, so dont know how,do know a bit about i2c, what is part number?
isnt external used with watch battery so it doesnt forget the time?
might be a good idea!
pixel(x,y,c)
0 = OR the pixel to the screen ie... add the new data to the old
1 = AND the pixel to the screen ie.. Only if the pixel was already lit it will stay lit ( in other words delete it )
2 is the one to use... XOR the pixels... This will light the pixel if it was off and extinguish if it was on..
