(Solved)Again problem with matrix, this time 8x32
except that last row....
int dataPin = 2;        //  ic: 14, ser_in Define which pins will be used for the Shift Register control
int latchPin = 3;      //   ic:12         silkscreen numbers!
int clockPin = 4;
char displayPointer=0;           // for interrupt use...
static char font [80] =    //numbers stored here
  0x00, 0x7c, 0xa2, 0x92, 0x8a, 0x7c, 0x00, 0x00, // 0
  0x00, 0x42, 0xfe, 0x02, 0x00, 0x00, 0x00, 0x00, // 1
  0x00, 0x42, 0x86, 0x8a, 0x92, 0x62, 0x00, 0x00, // 2
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 3
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 4
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 5
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 6
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 7
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 8
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 9
unsigned char buffer[32];          // buffer for screen
unsigned char backbuffer[32];       // Spare screen for drawing on
char power[8]={128,64,32,16,8,4,2,1};
ISR(TIMER1_COMPA_vect)          // timer compare interrupt service routine
   unsigned char columndata;
   unsigned char columnnumber;
    if(TIFR2)               // Make sure its the timer interrupt.
     columndata= buffer[displayPointer];  // 32 bits of column
     columnnumber = displayPointer;
     setcolumn(columnnumber);
     setdata(columndata);
     digitalWrite(latchPin  ,HIGH);digitalWrite(latchPin , LOW ); // STORECLOCK
     if(++displayPointer==32) { displayPointer = 0;  }    // 32 LED row sections in total
   TIFR2 = 0;               // Clear timer 2 interrupt flag
void setcolumn(unsigned char col){
  unsigned char pos;
col++;
for (pos = 32;pos>0;pos--){
if (col == pos){digitalWrite(dataPin ,HIGH);}else {digitalWrite(dataPin ,LOW);}     // PIN1 DATA pin
digitalWrite(clockPin   ,HIGH);digitalWrite(clockPin  ,LOW);
void setdata(unsigned char dat){
  unsigned char pos;
for (pos = 0;pos<8;pos++){
if (dat & 128){dat-=128;digitalWrite(dataPin ,HIGH);}else { digitalWrite(dataPin ,LOW);}      // PIN1 DATA pin
dat = dat * 2;
void pixel(signed char x,signed char y,int cond)
   int tmp;
   char pix,msk;
   if(x<0 || y<0) return;       // outside drawing limits negative
   if(x>31 || y>7) return;       // outside drawing limits positive
   tmp = (y << 2) + (x>>3);     // Linear position
   pix = x%8;             // pixel required
   pix = power[pix];
   msk = backbuffer[tmp];       // get exsisting data
   if(cond == 2)
     pix ^= msk;           // XOR data to screen
   if (cond == 1)
     pix = ~pix;
     pix &= msk;           // AND data to screen
   if(cond == 0)
     pix |= msk;           // OR data to screen
   backbuffer[tmp] = pix;       // apply changes
void charput(char ch, signed char x,signed char y)
   signed char x1, y1;
   const char* addr2;         // pointer to character
   char disp;
   ch -= 0x20;             // characters starts a 0 not 0x20
   addr2 = &font[0];         // start of font array
   addr2 = addr2 + ((int)ch * 8);   // start place in font array
   for( y1=0;y1<8;y1++)       // eight rows
     disp = *addr2;
     for (x1 = 0; x1<8; x1++)   // eight pixels
       if(disp & power[x1])
         pixel(x+x1,y+y1,0); // OR the pixel to the display buffer
     addr2++;
void strput(const char* ch, signed char x,signed char y)
   int addr;
   while (*ch )
     charput(*ch++,x,y);       // write a string to the display buffer
     x+=7;
void clr()                   //clear
   int addr;
   for(addr=0;addr<32;addr++)         // Empty display buffer
     backbuffer[addr]= 0;
void Blit()              //transfers data between display buffer to screen buffer
   int addr=0;
   noInterrupts();           // disable all interrupts during setup
   for(addr=0;addr < 32;addr ++)
     buffer[addr] = backbuffer[addr];   // put all data from display buffer
     }                   // to screen buffer
   interrupts();             // enable all interrupts
void displaystring(void)         // this routine prints through the screen buffer
   {                   // moving one pixel at a time
   signed char x=32,y=0;         // I made these signed so I could print
   for(y = 0;y  < 32 ;y++)         // to nowhere so I could produce the scrolling effect
     clr();               // Clear the display buffer
    backbuffer[y] = y/4 + 1;
     Blit();               // pass to screen buffer
     delay(500);           // time to view
void setup()          //setup runs once
    DDRD = DDRD | B11111100;  //port registers used to set pin directions
   //int sx,sy;   //these two necessary? couldn't see them anywhere else than ball-thingy
   //int xdir=1, ydir=1;
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
  OCR1A = 31250;            // compare match register 16MHz/256/2Hz
  TCCR1B |= (1 << WGM12);   // CTC mode, free-running, clear on match
  TCCR1B |= (1 << CS12);    // 256 prescaler
  TIMSK1 |= (1 << OCIE1A);  // enable timer compare interrupt
   displaystring();  //prints just hello world at startup
   while(1)         //essentially loop()? but loop is still needed...
     clr();    //clear buffer first
     /*sx += xdir; sy += ydir;     no balls needed so can be omitted
  strput("]",sx,sy);      // this is a ball character for bouncing routine
     if(sx>27) xdir = -1;      /// Wall limits
     if(sy>4) ydir = -1;
     if(sx<0) xdir = 1;
     if(sy<0) ydir = 1;*/
     delay(80);    //delay, but won't effect ISR
     Blit();       //swap buffers
   }   // End main
   void loop() //just sitting here
I'll just cut/place tape on top of that last row....
Last code took care of that thankfully, so same result as earlier video, except that last row :) so, last row doesn't show binary anymore
hope you are joking there, I want to make sure that buffer is aligned properly..... (and that i did math right, when i added +1 instead of subtracted 1), i am concerned cause that black screen should not have happened when it did,
if its truly working here is another:
int clockPin = 4;
  unsigned char pos;
col++;
  unsigned char pos;
dat = dat * 2;
   int tmp;
   char pix,msk;
   pix = power[pix];
   if(cond == 2)
   if (cond == 1)
     pix = ~pix;
   if(cond == 0)
   signed char x1, y1;
   char disp;
     disp = *addr2;
     addr2++;
   int addr;
   while (*ch )
     x+=7;
void clr()                   //clear
   int addr;
   int addr=0;
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
     if(sy>4) ydir = -1;
     if(sx<0) xdir = 1;
   }   // End main
It truly did work, but now that code doesn't work, only one led blinks at start, where previous video showed as start. So leftmost-upper led blinks once, that's all it does.
int clockPin = 4;
  unsigned char pos;
col--;
  unsigned char pos;
dat = dat * 2;
   int tmp;
   char pix,msk;
   pix = power[pix];
   if(cond == 2)
   if (cond == 1)
     pix = ~pix;
   if(cond == 0)
   signed char x1, y1;
   char disp;
     disp = *addr2;
     addr2++;
   int addr;
   while (*ch )
     x+=7;
void clr()                   //clear
   int addr;
   int addr=0;
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
     if(sy>4) ydir = -1;
     if(sx<0) xdir = 1;
   }   // End main
sry, its still early, i almost though you did actually tape it!
lol :D
Last code counted binary left to right, like in post #100, but doesn't light up last column. :)
This one should be good!
int clockPin = 4;
  unsigned char pos;
//col--;
  unsigned char pos;
dat = dat * 2;
   int tmp;
   char pix,msk;
   pix = power[pix];
   if(cond == 2)
   if (cond == 1)
     pix = ~pix;
   if(cond == 0)
   signed char x1, y1;
   char disp;
     disp = *addr2;
     addr2++;
   int addr;
   while (*ch )
     x+=7;
void clr()                   //clear
   int addr;
   int addr=0;
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
     if(sy>4) ydir = -1;
     if(sx<0) xdir = 1;
   }   // End main
Binary counter without that last column :)
int clockPin = 4;
  unsigned char pos;
col++;
for (pos = 33;pos>0;pos--){
  unsigned char pos;
dat = dat * 2;
   int tmp;
   char pix,msk;
   pix = power[pix];
   if(cond == 2)
   if (cond == 1)
     pix = ~pix;
   if(cond == 0)
   signed char x1, y1;
   char disp;
     disp = *addr2;
     addr2++;
   int addr;
   while (*ch )
     x+=7;
void clr()                   //clear
   int addr;
   int addr=0;
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
     if(sy>4) ydir = -1;
     if(sx<0) xdir = 1;
   }   // End main
binary counter still working, no last column problem :)
from left to right
int clockPin = 4;
unsigned char pos;
//col++;
unsigned char pos;
dat = dat * 2;
int tmp;
char pix,msk;
pix = power[pix];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
char disp;
disp = *addr2;
addr2++;
int addr;
while (*ch )
x+=7;
void clr() //clear
int addr;
int addr=0;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
} // End main
Yup, same result, still working!
so still no last column? post 112 should work, first try as is , if not edit void setcolunm(), change //pos++; to pos++; and if that dont work either try pos--;
it should be changing results a bit, we need to get that last column aligned!
there wasn't //post++;, but there was //col++ this is code that now worked all the way! :)
C:
int clockPin = 4;
unsigned char pos;
col++;
unsigned char pos;
dat = dat * 2;
int tmp;
char pix,msk;
pix = power[pix];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
char disp;
disp = *addr2;
addr2++;
int addr;
while (*ch )
x+=7;
void clr() //clear
int addr;
int addr=0;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
} // End main
good eye , it was col! so all the the lights are good now?
good good, that completes the hdw conversion then, but now we need to figure out how to get that pixel function goin, also i want to do a test on display string, i think it was acting funky earlier as well....it should make the same display , but all lights at once
try this:
old code:
Hmm only first led blinks once?
dont like, or get why its doin that, but lets hold off for now, and hope insight will appear!
lets try and see if pixel works now!
pixel(1,1,0);pixel(1,2,0);
pixel(2,1,0);pixel(2,2,0);
pixel(3,3,1);pixel(3,4,1);
pixel(4,4,2);pixel(4,5,2);
will be different output ,blinks are significant, because as we debug, we are comparing the response of input vs output, in that example we send input to 8 pixels, my guess is that 4 will light solid, and i am curious to what the other 4 will do..
