(Solved)Again problem with matrix, this time 8x32
Here we go, shot from last one:
not what i would like at all , but keep code from post 118 for now,
change this part though:
void pixel(signed char x,signed char y,int cond)
int tmp;
char pix,msk;
if(x<0 || y<0) return; // outside drawing limits negative
if(x>31 || y>7) return; // outside drawing limits positive
pix = power[y];
msk = backbuffer[x]; // get exsisting data
if(cond == 2) { pix ^= msk; } // XOR data to screen
if (cond == 1) { pix = ~pix; pix &= msk; } // AND data to screen
if(cond == 0) { pix |= msk; } // OR data to screen
backbuffer[tmp] = pix; // apply changes
Only one led blinks once, leftmost-upper, here's code, I'm quite I put it right:
Sorry, code attach didnt work....
C:
int dataPin = 2; // ic: 14, ser_in Define which pins will be used for the Shift Register control
int latchPin = 3; // ic:12 silkscreen numbers!
int clockPin = 4;
char displayPointer=0; // for interrupt use...
static char font [80] = //numbers stored here
0x00, 0x7c, 0xa2, 0x92, 0x8a, 0x7c, 0x00, 0x00, // 0
0x00, 0x42, 0xfe, 0x02, 0x00, 0x00, 0x00, 0x00, // 1
0x00, 0x42, 0x86, 0x8a, 0x92, 0x62, 0x00, 0x00, // 2
0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 3
0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 4
0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 5
0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 6
0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 7
0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 8
0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 9
unsigned char buffer[32]; // buffer for screen
unsigned char backbuffer[32]; // Spare screen for drawing on
char power[8]={128,64,32,16,8,4,2,1};
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine
unsigned char columndata;
unsigned char columnnumber;
if(TIFR2) // Make sure its the timer interrupt.
columndata= buffer[displayPointer]; // 32 bits of column
columnnumber = displayPointer;
setcolumn(columnnumber);
setdata(columndata);
digitalWrite(latchPin ,HIGH);digitalWrite(latchPin , LOW ); // STORECLOCK
if(++displayPointer==32) { displayPointer = 0; } // 32 LED row sections in total
TIFR2 = 0; // Clear timer 2 interrupt flag
void setcolumn(unsigned char col){
unsigned char pos;
col++;
for (pos = 33;pos>0;pos--){
if (col == pos){digitalWrite(dataPin ,HIGH);}else {digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
digitalWrite(clockPin ,HIGH);digitalWrite(clockPin ,LOW);
void setdata(unsigned char dat){
unsigned char pos;
for (pos = 0;pos<8;pos++){
if (dat & 128){dat-=128;digitalWrite(dataPin ,HIGH);}else { digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
dat = dat * 2;
int tmp;
char pix,msk;
pix = power[y];
void charput(char ch, signed char x,signed char y)
signed char x1, y1;
const char* addr2; // pointer to character
char disp;
ch -= 0x20; // characters starts a 0 not 0x20
addr2 = &font[0]; // start of font array
addr2 = addr2 + ((int)ch * 8); // start place in font array
for( y1=0;y1<8;y1++) // eight rows
disp = *addr2;
for (x1 = 0; x1<8; x1++) // eight pixels
if(disp & power[x1])
pixel(x+x1,y+y1,0); // OR the pixel to the display buffer
addr2++;
void strput(const char* ch, signed char x,signed char y)
int addr;
while (*ch )
charput(*ch++,x,y); // write a string to the display buffer
x+=7;
void clr() //clear
int addr;
for(addr=0;addr<32;addr++) // Empty display buffer
backbuffer[addr]= 0;
void Blit() //transfers data between display buffer to screen buffer
int addr=0;
noInterrupts(); // disable all interrupts during setup
for(addr=0;addr < 32;addr ++)
buffer[addr] = backbuffer[addr]; // put all data from display buffer
} // to screen buffer
interrupts(); // enable all interrupts
void displaystring(void) // this routine prints through the screen buffer
{ // moving one pixel at a time
signed char x=32,y=0; // I made these signed so I could print
for(y = 0;y < 32 ;y++) // to nowhere so I could produce the scrolling effect
clr(); // Clear the display buffer
pixel(1,1,0);pixel(1,2,0);
pixel(2,1,0);pixel(2,2,0);
pixel(3,3,1);pixel(3,4,1);
pixel(4,4,2);pixel(4,5,2);
Blit(); // pass to screen buffer
delay(500); // time to view
void setup() //setup runs once
DDRD = DDRD | B11111100; //port registers used to set pin directions
//int sx,sy; //these two necessary? couldn't see them anywhere else than ball-thingy
//int xdir=1, ydir=1;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 31250; // compare match register 16MHz/256/2Hz
TCCR1B |= (1 << WGM12); // CTC mode, free-running, clear on match
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
displaystring(); //prints just hello world at startup
while(1) //essentially loop()? but loop is still needed...
clr(); //clear buffer first
/*sx += xdir; sy += ydir; no balls needed so can be omitted
strput("]",sx,sy); // this is a ball character for bouncing routine
if(sx>27) xdir = -1; /// Wall limits
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
if(sy<0) ydir = 1;*/
delay(80); //delay, but won't effect ISR
Blit(); //swap buffers
} // End main
void loop() //just sitting here
was put right...
int clockPin = 4;
unsigned char pos;
//col++;
unsigned char pos;
dat = dat * 2;
int tmp;
char pix,msk;
//tmp = (y << 2) + (x>>3); // Linear position
//pix = x%8; // pixel required
pix = power[y];
if(cond == 2)
pix ^= msk; // XOR data to screen
if (cond == 1)
pix = ~pix;
pix &= msk; // AND data to screen
if(cond == 0)
pix |= msk; // OR data to screen
backbuffer[x] = pix; // apply changes
signed char x1, y1;
char disp;
disp = *addr2;
addr2++;
int addr;
while (*ch )
x+=7;
void clr() //clear
int addr;
int addr=0;
pixel(31,7,0);pixel(31,6,0);
pixel(30,7,0);pixel(30,6,0);
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
} // End main
oop,s forgot to press enter...
So, blank screen on that one :O
int clockPin = 4;
unsigned char pos;
//col++;
unsigned char pos;
dat = dat * 2;
int tmp;
char pix,msk;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
char disp;
disp = *addr2;
addr2++;
int addr;
while (*ch )
x+=7;
void clr() //clear
int addr;
int addr=0;
clr();
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
//clr(); //clear buffer first
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
//delay(80); //delay, but won't effect ISR
//Blit(); //swap buffers
} // End main
well, at least alive:
:) lets cross fingers!!!
int clockPin = 4;
unsigned char displayPointer=0; // for interrupt use...
unsigned char buffer1[32]; // buffer for screen
unsigned char power[8]={128,64,32,16,8,4,2,1};
setcolumn(displayPointer);
setdata(buffer1[displayPointer]);
signed char pos;
for (pos = 32;pos>-1;pos--){
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
buffer1[addr] = backbuffer[addr]; // put all data from display buffer
unsigned char pix,msk;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
clr();
pixel(1,1,0);
pixel(2,2,0);
pixel(3,3,0);
pixel(4,4,0);
pixel(5,1,0);
Blit();
delay(500);
Hmm, there appears rising patter from leftmost matrix:
BAM! Thats the Pixel() function working! Next we will just expand that a bit to check the corners,
I am concerned though it should be moving faster, it looks like ISR() is not being called fast enough, i wonder if there is way to speed it up...
int clockPin = 4;
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
clr();
pixel(0,0,0);
pixel(0,1,0);
pixel(1,0,0);
pixel(1,1,0);
pixel(2,2,0);
pixel(3,3,0);
pixel(4,4,0);
pixel(5,1,0);
pixel(31,8,0);
pixel(30,8,0);
pixel(31,7,0);
Blit();
delay(5000);
My replies might take while, I make paracrod stuff at same time.... another hobby lol.
But, that didn't affect speed much, what about manipulating
^this line? or does it blew up timer sequence? At least when I have done so, at first it does go well but in certain value nothing is drawn in screen.
Oh BOTTOM, yes sorry! will upload shot in a few...
int clockPin = 4;
0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, // 0
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, // 1
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
const uint8_t* addr2; // pointer to character
char disp;
disp = *addr2;
addr2++;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
clr();
pixel(0,0,0);
pixel(31,7,0);
charput( 0,0,0);
charput( 8,0,1);
charput( 16,0,2);
Blit();
delay(500);
ehh :D...
C:
Arduino: 1.6.5 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
sketch_jan15a.ino: In function 'void charput(char, signed char, signed char)':
sketch_jan15a:96: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
int clockPin = 4;
static unsigned char font [80] = //numbers stored here
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
const unsigned char addr2; // pointer to character
char disp;
disp = *addr2;
addr2++;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
clr();
pixel(0,0,0);
pixel(31,7,0);
charput( 0,0,0);
charput( 8,0,1);
charput( 16,0,2);
Blit();
delay(500);
