Thanks. The amps has no idle current yet and I think it should by now.
Okay, I've checked into this and I realized I made a major mistake. Because I have the bulb limiter after the Variac, the voltage measured at my Kill-A-Watt, which is plugged into my Variac, is not the voltage at my amp. I put my multimeter across the AC side of the amp's rectifier and measured 51 VAC. That means all the values I posted previously were not at 90VAC, but 51VAC.
Sorry about that. Wasn't thinking. I'm not sure what that means for the current reading measured by the Kill-A-Watt, as the 40W bulb in the limiter must have been responsible for part of that current.
I think I have to reverse things . . . plug the bulb limiter into the mains outlet, then plug the variac into the limiter. Then (I think) the Kill-A-Watt will give me the right voltage and current. NOPE. Just tried it. I can't get the Variac, Kill-A-Watt and multimeter to agree. Maybe it's time to ditch the bulb limiter?
Still . . . I wonder if there should have been half of that 90mV idle current, even at 50 VAC? Or do you think it needs more than 50 VAC before we start to see idle current?
Sorry for the goof-up . . . I'm learning.
Thanks for all the help . . . you're helping me learn (as are my mistakes).
Peace,
Bud
