I'm having yet another switching problem:
I want to make footswitch, which turns on an effect. The problem is that, when the effect is switched on, it requires to activate the switch another time to turn the effect off.
I want to eliminate the latter. That means, I want to press the pedal only for as long as the effect is needed and when I let the pedal go, the effect should turn off.
That also means that the switching circuit needs to automatically activate the switch another time to turn the effect off.
How can that be done?
**broken link removed** Click Image to Enlarge **broken link removed**
