There is no PFC function in the post#37 circuit, which is the one I was referring to in post #38.the load should be more resistive due to the PFC function
Aha, I see. I meant post #36, with the boost PFC converter. Sorry that I was unclear.There is no PFC function in the post#37 circuit, which is the one I was referring to in post #38.
Don't understand your results.My faith in Spice's power calculations is being tested .
It seems your circuit can achieve over-unity!! If you set the sim period to 10mS and start saving data at 2mS, then over the 8mS interval the average 'power' provided by V1 is ~791.9W but the average power dissipated in R1 is 795.7W .
[Explainable by the load seen by V1 being primarily inductive]
It calculates the VA numbers, which is apparent power.SPICE sees 1000*10 and -500*10 and generates very large "power" numbers.
On a capacitor, if the start voltage is the same as the end voltage then the flow of electrons must equal zero. (current average =0)It's the average of those calculations over an integral number of complete waveform cycles that's the real power.
Which LTspice version are you using?We must have something different in our settings.
The error is reduced if you average the value over many integral waveform cycles.Two people measuring power over one PWM cycle must agree on which cycle they are measuring.
XV11.Which LTspice version are you using?
Same one I used.XV11
Would 10 ms be enough to run the simulation as it is DC in the input?I tried with and without 'Skip initial operating point solution' enabled, but that made no difference.
In Control Panel/Spice I do have Trtol set to 7, if that's relevant.
Edit: Yup, that's what accounts for the difference. With Trtol=1 I duplicate your result, Crutschow.
Yes, that's true. But if I only measuring power losses for the other components, diodes, mosfets and resistor, I can obtain the real power.I would think the longer you run the simulation the closer you will get to a stable situation. However, as Crutschow has pointed out, LTS is computing apparent power, not real power, for reactive components.
Yes, that's the same average...........
Is that average the same as we can read from the simulation window when we are measuring power dissipation?
CrutsChow,And the capacitor average power, as expected, is essentially zero
Wow. You did it. I thought I did this a week ago and got many watts.Here you go:
