The easiest wat to do it is with a ROM. That's a Read Only Memory. You take the first sixteen locations and write the pattern of 1's and 0's that corresponds to the input on the address lines. Tie the other address lines low and tie the chip select low.phu hung said:
Help me make the circuit 4 inputs and 8 outputs works like IC 7447![]()
THANK YOU!!!
THANK YOU!!!
