the program is not runing in C
sxy
#include <stdio.h>
int multiplication(int a,int b)
int c;
c=a*b;
return c;
void main(void)
int r;
r = multiplication(2,8);
printf(“%d”,r);
I should get 16 but it is not runing.
why?
thanks a lot
Well, I've run into a similar problem few days ago (I'm also C beginner).
Answer to my problem was, that scanf() is reading until it reaches something it cannot read (if there's int, then str, etc.), so try put there something, that's not a number (e.g. if you want to use input 24, then write: "24 x")
Hopefully this helps :)
router login
picashow
I don't have the strength to deal with it. Downloading software shouldn't be such a complicated thing.
Maybe proramming isnt for you then as stuff like this is what programming is all about.
are you DL the right program, ru x86/64 , got enough ram, correct win ver... ect, maybe try a older ver of studio, i DL 2015 last week cos it was the only free one that works with my Pc.
try your own h scripts, using prebuilt(someone elses) leaves you susceptible to their code and their mistakes.
