Mosaic
Hi All:
Yes, i have just hacked (literally) another MOT.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyway, I am using it for an electronics power supply.
Since the Magnetizing current (no load) was about 12 Amps I decided to add some copper. 40 turns later the current is down to 2.75A which is ok.
The secondaries use 18 AWG for a 25.4 VAC CT output and 12 AWG for a 13.4VAC output.
The core area of 64mm x 35mm works out to about a 375VA unit.
My question is:
If I expect to draw a max load of 8A from the 25.4 VAC secondary = 203VA, does this mean that I can draw 375-203 = 172 VA or 12.8A from the 13.4VAC secondary?
Also, at full draw 375 VA/120VAC = 3.125 A in the primary. Does this add on to the no load magnetizing current of 2.75A?
My question is:
