It depends upon how the transistor is configured. It can be configured to provide:-Gaston said:as i understand it, common emmiter is for voltage gain, and common collector is for current gain. is that correct? and what would you use a common base for?
The only time I've seen a common base configuration used, was as an RF amplifier stage in a radio reciever. It's low input impedance is easy to match to the 50and what would you use a common base for
