If you are pulsing the triac for speed control, but I doubt it, motors require special considerations.
Hi.. thanks for the doc, you gave it to me before and thats what i am following.Most Triacs can be triggered by a DC voltage of either polarity. But the current required varies depending on which quadrant it is in at the moment. See this document for an explanation of the quadrants. https://www.littelfuse.com/~/media/...lding_of_SCRs_and_Triacs_Application_Note.pdf
See the individual data sheet for the triac you are using to get it's requirements.
This document has good info on connecting triacs and uControllers. https://www.littelfuse.com/~/media/...rol_Using_Thyristors_Application_Note.pdf.pdf
I have BTA16 600BW the normal and cheap type.Triac datasheet: https://www.st.com/web/en/resource/technical/document/datasheet/CD00002265.pdf
What suffix part are you using?
