Triggering SCR with neon
johntee
I came across this strobe circuit on the web and question whether the neon "NE2" is configured correctly to trigger the SCR on its gate.
John
John
hi
When the voltage across NE2 reaches its breakdown voltage, the current tiggers the SCR on, this discharges the capacitor thru the high voltage trigger transformer primary winding, causing a 'flash'
Thanks Eric, wasn't sure how the neon developed the build up voltage in this circuit, other similar circuits seem to feed the neon voltage through a 1 meg resistor into a charge capacitor and then feed the other side of the neon into the SCR gate like this:-
Cheers,
John
My numbers might off by a few... But a neon lights at around 70 volts, which also where the gas starts to conduct. The xenon needs 250-300 volts to light, plus in needs a high voltage arc to ionize a path (3 kV or so). The resistor makes sure the neon doesn't conduct, until the capcitor is charged enough to light the xenon.
Cheers Harvey, the coins dropped. Think my old gray matter needs a recharge somedays ................ today being one of those !!
Kind regards,
John
