I am aware of how to use vent holes. The idea is to make my design more efficient then the others. The design that your showing is like all of the others out there. There has to be something that i can do to add to the other designs.
You put the Peltier in the wall such that the cold side is on the outside of the box and the warm side is on the inside. A large heatsink (and a small fan if necessary) should keep the cold side from icing up. That will give you a heater that is more than 100% efficient as compared to a resistor.With my understanding of Peltiers, don't they heat on one side and cool on the other side? If they do They would contradict themselves in a sealed en-closer. right? How are you suggesting that i use the peltier?![]()
