After cleaning and lighting PCB from bottom side with my camera flash on phone, I have found that track is clearly broken on joint with resistor R2. Cut is a size of a hair, so how to repair this?
Is there some chemical for that, maybe acetone?Solder a wire across it - or if it's just a crack, a simple blob of solder.
You will need to scrape the resist off the copper first - a very small chisel (or more likely a small sharpened screwdriver) is good for this.
Done it. Just need to solder it, in a couple of days.Just scape it off - it only takes seconds.
How to clean residue?You have used too much heat, solder and probably a very large soldering iron tip.
Firstly, you need to thoroughly clean the residue from the soldering. Have the resistor pads for R2 also been damaged?
The solder on the carbon button contact should also be removed very carefully.
Watch some videos on YouTube on surface mount soldering techniques before attempting it again.
I only have avaliable 1/4 watt.Just replace the SM resistors with small (1/10th watt?)
