The thread started back in 2013 (https://www.electro-tech-online.com/threads/neeed-some-help-with-dual-pir-sensor-circuit.138698/) is extremely close to what I need but as the parts I'm using are a bit different and the thread had a shift a few years later, I thought a new topic might be better than reactivating that one.
But indeed, this is also a setup to drive LED lights with two PIRs, in this case along a driveway with a PIR at each end so arriving and departing vehicles can trigger the lights.
The DC>DC solid state relay I'm using has a wide control voltage (3-32DC @ 3-25mA) and the 12v DC PIRs I am getting are designed to drive items such as LED lights up to 100w @ 12vDC but I do not have any real specs for them beyond that. The load side of the PIRs will only be driving the relay.
The original diagram discussed in that old thread was using a transistor to adjust voltage for the relay and honestly, confused me a bit so the attached diagram is what I think I should be doing.
