Virtual ground simulation
Roff
This sim works with other op amps I have tried (only 2 or 3 others), but TL072 gets it all wrong, at least using the model that I have.
Has anyone else seen this?
  • virtual ground.asc
hi Ron,
My model suffix is .301 from YLTS.
I got exactly the same result values as you did.
The only work around I could find, is the 'COM' symbol on the 072 output.
Eric
  • virtual ground2.asc
Hi Eric,
SgtWookie on AAC found that TI had used GND (node 0) in their models. He changed them to the vee node, and all was well.
I believe SgtWookie also posts here, but under a different name.
Are you there, Wookie?
I've had the impression not, but if he does I would be interested in knowing.
Ahhh... I had never heard it called that.
Sorry Ron, I guess the txtspeak virus has infected my brain.
Did you get any further with a solution.? I think SgtWookie is aka on ETO as SgtWook
