Wake up LCD !!
ttbuddy
I was building a simple wattmeter using the schematic as shown here
And the ASM code for PIC16F88 here to drive the JHD162A LCD as well.
(The code is on 4 bits HD44780, but is compatible with KS0066 driver used here.)
However after I'd built the circuit, I found that LCD shows nothing.
And I wonder if I had done something wrong on my code or what, or maybe thay said I need some kind of driver "wake-up" for the LCD module?
Thanks if you can help.
Have you selected a PIC type for this conditional compile..??
Also
Have you adjusted R1 the 'VO' contrast pot so that the pixel blocks are just visible.
[COLOR="Red"][B];	processor  PIC16f870
;	processor  PIC16F88
[/B]
[/COLOR]	ifdef	__16F870
	include	P16f870.inc
#DEFINE TMR0IF	T0IF
	else
	include	P16F88.inc
	endif
	errorlevel -302,-305	; not reporting bank<>0, dest=file
#DEFINE FALSE 0
#DEFINE movfw ERROR movwf?
	ifdef	__16F870
 __config _BODEN_OFF&_WDT_OFF&_LVP_OFF&_PWRTE_ON&_HS_OSC
	else   ; 16F88
 __config _CONFIG1,_BODEN_OFF&_WDT_OFF&_LVP_OFF&_MCLR_OFF&_PWRTE_ON&_INTRC_IO
	endif
; I/O pin assignments
	ifdef	__16F870
#DEFINE	PGBTN	PORTC,0	; page button
#DEFINE	HDBTN	PORTC,1	; hold button
#DEFINE	BLDBTN	PORTC,3	; blades button
#DEFINE	RPMIN	PORTC,2	; rpm input
#DEFINE LCD_D7  PORTB,0	; \
#DEFINE	LCD_D6  PORTB,1	; |
#DEFINE LCD_D5  PORTB,2	; | LCD panel
#DEFINE LCD_D4  PORTB,3	; |
#DEFINE LCD_E   PORTB,4	; |
#DEFINE LCD_RS  PORTB,5	; /
	else    ; 16f88
#DEFINE	PGBTN	PORTB,6	; page button
#DEFINE	HDBTN	PORTB,7	; hold button
#DEFINE	BLDBTN	PORTA,7	; blades button
#DEFINE	RPM_IN	PORTB,0	; rpm input
#DEFINE LCD_D7  PORTA,4	; \
	endif
Also
[/B]
	include	P16f870.inc
#DEFINE TMR0IF	T0IF
	else
	include	P16F88.inc
	endif
#DEFINE FALSE 0
	ifdef	__16F870
	else   ; 16F88
	endif
	ifdef	__16F870
	else    ; 16f88
	endif
Thanks for your reply....
May i know what do you mean by PIC type?
I am using MPLAB IDE to compile and burn it to PIC....
I use #defines and directives to make the program easier to
read and modify. For example, the status of the Hold button
is determined by examining bit 7 of PortB on the 16F88, but
it's bit 3 of PortC on the 16F870. I want to write the same
code for both, so I define the port and bit for each MPU, and
use the assembler directives 'ifdef', 'else', and 'endif' to
select the code used depending on which processer is selected.
Then, when I need to read the port pin, the same instruction
works for both PIC's, eg.
ifdef __16F870 ; '__16F870' exists when MPU=16F870
#DEFINE BLDBTN PORTC,3 ; blades button 16F870
else
#DEFINE BLDBTN PORTA,7 ; blades button 16F88
endif
hi
As you are using a 16F88 , then remove the semi-colon from the start of processor PIC16F88
processor PIC16F88
I have tried to compile your code using Oshonsoft, it reports it cannot find the
include LCD.asm file
Have downloaded this from the wattmeter site.??:)
EDIT:
I am familiar with and use conditional assembly directives.
hi
processor PIC16F88
EDIT:
I am famliar with and use conditional assembly directives.
Oh yes... i put LCD.asm into the same directory and compile it...
successfully built the .HEX file.
Are you expert in ASM by the way?
May I know the IO that is interface with the LCD module? (The last 4 bits)...
Is that code responsible to drive onli for the LCD? If i tried to connect the IO to another IO of other module, what will i obtain? Thanks for your help.
Are you expert in ASM by the way? I have had my moments.!
Post the LCD.asm file so that I can compile the full program, in that way I can help you better.:)
I'll look at the circuit you have posted.
A quick look at the circuit shows that the VO contrast line is connected to a -V supply.!!
I assume that the LCD is HD44780 compatible, if yes, the VO should be settable to 0V thru to +5V.
Please confirm the type of the LCD.
Also what the Source and Load lines are connected too.?
you mean connecting the VO to the +5V instead of 0V?
please confirm the type of the LCD.
BTW: the code will not assemble without many errors [ I have the LCD.asm] .
Did you say that you have compiled this source code in MPLAB.???
The LCD i use is JHD 162A with 16 pins...
i'd searched thru the internet that its controller is KS0066 driven ..
Well for the source, I use the 9V battery and the load can be anything resistance ...
P/S: The source "-" and 0V is connecting to the same rail at the negative terminal of the source.
I have looked at this JHD pdf.
What I was concerned about was the fact that the PIC is running from 3.3V and I am not 100% sure if the JHD will work at 3.3V.???
Did the code that you posted compile without errors.?
  • jhd162a.pdf
Been looking at the JHD specs, it has a Samsung KS0070B controller, which suggests a +5V nominal supply voltage.??
EDIT:
Using the posted assembler code for the wattmeter and lcd in MPLAB for a 16F88 produces 240 ERRORS.!
Did you say you have compiled this code.?
  • KS0070B.PDF
EDIT:
Well, yes, i tried to measure the voltage.
I use 9V source supply and I measured the voltage at the Vdd as 1V, Vout around 0.2V.
By the way, I compiled the code using MPLAB IDE and i get this:
Debug build of project `D:\Watt Meter (desired design)\wattmeter.mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Fri Jan 23 18:18:22 2009
Clean: Deleting intermediary and output files.
Clean: Deleted file "D:\Watt Meter (desired design)\wattmeter.err".
Clean: Deleted file "D:\Watt Meter (desired design)\wattmeter.cod".
Clean: Deleted file "D:\Watt Meter (desired design)\wattmeter.hex".
Clean: Deleted file "D:\Watt Meter (desired design)\wattmeter.lst".
Clean: Deleted file "D:\Watt Meter (desired design)\wattmeter.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F88 "wattmeter.asm" /l"wattmeter.lst" /e"wattmeter.err" /d__DEBUG=1
Loaded D:\Watt Meter (desired design)\wattmeter.cod.
Debug build of project `D:\Watt Meter (desired design)\wattmeter.mcp' succeeded.
Fri Jan 23 18:18:24 2009
BUILD SUCCEEDED
I guess there is the problem with the voltage..
but using the pre-existing schematic...
i wonder how can i up the voltage to 5V... sigh..
The KS0066 datasheet shows low voltage operation.!!!!
Why dont you write a simple LCD driver diagnostic program and debug that.:)
  • mXuuzvr.pdf
Thanks, will try it...
may i know the function of the contrast ? using potentiometer?
The contrast setting varies the intensity [light/dark] of the LCD pixels, from OFF [invisible] to full ON [all black blocks].
Set it to give the best viewing contrast for your application.
Well, as you suggest, I tried to diagnostic my PIC and LCD module,
by referring to **broken link removed**.
I am using the PCWH to compile and get the HEX file.
The main program code:
#include <16F88.h>
#fuses HS,NOWDT,PUT,NOLVP
#use delay(clock=20000000)
#include "flex_lcd.c"
void main()
lcd_init();  // Always call this first.
lcd_putc("\fHello World\n");
lcd_putc("Line Number 2");
while(1);
And I modified the flex_lcd.c to meet my PIC:
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_B0
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_B2
#define LCD_DB7   PIN_B3
#define LCD_RS    PIN_B4
#define LCD_RW    PIN_B5
#define LCD_E     PIN_B6
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW   1
#define lcd_type 2        // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
 0xc,                    // Display on
 1,                      // Clear display
 6                       // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2));
 output_bit(LCD_DB6, !!(nibble & 4));
 output_bit(LCD_DB7, !!(nibble & 8));
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
   output_high(LCD_RS);
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
#endif
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 60 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_LCD_RW
    delay_ms(5);
    #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
   address = lcd_line_two;
else
   address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1,2);
       break;
    case '\b':
       lcd_send_byte(0,0x10);
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
#endif
I am using the LM2936-3.3V to drive both the LCD and the PIC.
The connection like this:
From PIC -> LCD
RB0 (6) - DB4 (11)
RB1 (7) - DB5 (12)
RB2 (8) - DB6 (13)
RB3 (9) - DB7 (14)
RB4 (10) - RS (4)
RB5 (11) - RW (5)
RB6 (12) - E (6)
PIC: pin 5 to 0V and pin 14 to 3.3V
LCD: pin 1 to 0V, pin 2 to 3.3V, pin 3 to contrast 10K
However i also see nothing... i just able to contrast at line two. :confused:
hi tt,
I'm sorry I dont use 'C' programming at all.:eek:
