I am using a Parallax SX28 micro-controller chip to control 2 cascaded Absen-OF20V 16x8 RGB modules from China. See attachments. What I don't see on this display is PWM control. The SX28 chip has a PWM command but it is used with a resistor and capacitor to create an analog voltage. I don't see how this can be used with this SPI display (very similar to the way a 74HC595 works). I do have Latch, /OE, CLK and Serial Data In and Serial Data Out on each of the cascaded chinese MBLOCK MBI5024GF constant current LED driver ICs. Currently I can turn on any of the 3 RGB LEDs over both of the 2 cascaded modules. Eventually I will have many more cascaded modules.
The SXB (BASIC) program was saved as a .TXT file (instead of the usual .SXB file)
I am new to PWM and need to know how to do this in a BASIC like language that the SX chip uses (SX/B). Can I get any help on this?
ALSO - I am currently using a spreadsheet to calculate the correct DATA statements since this display uses a different way to push data to the data streams (2). Is there a better way to do this? I should be able to modify the design for Serial port control and send out TEXT pages from HyperTerminal. But that is about it on my programming ability to the PC. Ideas for this too?
Thanks!
Thanks!
DI-P20F1%20outdoor%20led%20display%20panel%20module.pdf497.4 KB · Views: 898
