which browser are you using?
ok just did and everything run, what does this tell you?
Thanks :) It tells me your browser is decent. I got 2945 with Chrome, though ;)
You'd have to run it with different browsers on your computer panic mode.
Not necessarily. It tests the rendering times, image quality, and all those sorts of things specifically for the browser you're testing it on. Have you run it yourself, yet?
bah.. this is not my gaming machine, it has only wimpy integrated graphic...
so that's all it is? someone made little benchmark with couple of test, so what?
a number in "mine is bigger" competition? it does not solve anything, nor tells where to improve.
I just run my FireFox and it failed 4 tests (missing codecs). is it bad browser?
how can it be? unlike chrome, this one scores where it counts - it works on every website i use. take that... :D
hmmm, and IE just scored 3260? cmon...
So what about the browser Derstrom? The metric only has meaning on the same physical hardware with differing browsers... This is basic understanding of benchmark testing..
If it works for you, you're welcome to it. :) I have never had a problem with chrome, and if you did it obviously has to do with your computer, not the browser itself. Chrome works beautifully for me--better than IE and FF by a LONG shot. I'm not knocking your browser. I'm just saying that you shouldn't knock Chrome if your computer can't support it properly. :p
The problem with that statement panic mode is that you're only one user, and you're likely clinging to a browser from a failed perception.
Ah, I think I misunderstood what you said. You've got me wondering now.....
@panic mode, do you still have Chrome installed? If so, would you be willing to re-run the assessment using Chrome? I'd like to see the relative score, if that's okay wit you. Perhaps you had a bad installation of Chrome, and that's why it didn't always work.
IE looks awful, but i was joking on IE score, i never run it. Just wanted to see response.
But the test suite is not very good, I am not impressed.
For example it does not show the per test results, only overall score. That means if you are not sitting there
and staring at it trying to catch things yourself, you may never know what was run and what not
like name of the missing codec (not that i care).
Also not sure what is 7/7 supposed to be. I run it on FF trice and the first digit changes 4/7 3/7 6/7.
So now that I've wasted 30min of my life on total dud, trying to see something I don't care about,
and potentially fix something that may not need fixing, MrFlow is knocking my breadwinner computer.
now that is just mean :p
Panic mode, this is the way browsers will be judged in the future. HTML5 tests, standardized testing... If you have any browse or system that is scoring less than perfect for passed tests it doesn't mater the score, you're going to be missing out on something!
You click the score bar for the details. It will give you the results for each individual test.
so now i should run it again? :)
sigh, fine, now i will run it in IE for real...
ouch... 887 on IE (2/7)
makes Chrome and FF look like super stars... i see marketing at work here.
Internet Explorer
884 Points
Version infoMozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Win64; x64; Trident/5.0)Comment
Suite
Result
Rendering
59.24
renderGrid01
199.19 fps
renderGrid02
143.32 fps
renderGrid03
9.61 fps
renderPhysics
44.89 fps
HTML5 Capabilities
2/7
webglSphere
N/A
videoPosterSupport
Yes
videoCodecH264
N/A
videoCodecTheora
N/A
videoCodecWebM
N/A
workerContrast01
N/A
workerContrast02
N/A
gamingSpitfire
Yes (49.76 fps)
HTML5 Canvas
5.90
experimentalRipple01
9.49 fps
experimentalRipple02
3.66 fps
Data
11398.53
arrayCombined
4090.50 ops
arrayWeighted
31763.00 ops
DOM operations
2724.43
domGetElements
112485.94 ops
domDynamicCreationCreateElement
853.07 ops
domDynamicCreationInnerHTML
2517.50 ops
domJQueryAttributeFilters
1213.00 ops
domJQueryBasicFilters
702.00 ops
domJQueryBasics
972.50 ops
domJQueryContentFilters
754.12 ops
domJQueryHierarchy
3755.50 ops
domQueryselector
14596.00 ops
Text parsing
49830.40
stringChat
20515.50 ops
stringDetectBrowser
160771.70 ops
stringFilter
11672.00 ops
stringValidateForm
144927.53 ops
stringWeighted
55066.08 ops
something i fishy here, i was joking about IE score being high but now the Chrome score is 1060 even though all tests passed and are as smooth as before and only one test was run at a time and there i ton of free RAM and CPU is next to idle.
my verdict is that this test is not reliable measure.
example of page loading issue with Chrome (my Latin course):
The assessment depends on a lot of different things, so you will probably get different scores every time.
While we are on the subject of browsers, I have a couple of issues with FF that I can't fix.
First the easy one. I used to have an Add-on that did two things:
1. Showed the data rate when pages loaded.
2. Showed the actual link when you hovered over the link at the bottom of the page. I forget what it was or it just isn't working anymore.
I do miss it.
The second problem is intermittent and beyond hope.
Randomly LEFT-SHIFT keys are interpreted as Control keys. It NEVER occurs in say Microsoft Word. A capital R is the worst. A RIGHT-SHIFT-R always works correctly. A Control R is very detrimental.
I used I.E but I too hated it as it is very slow and takes a lot of time to load a page, for this reason I started using Firefox and to my surprise its far more better than I.E it gives a good speed and has many add ons that probably make my surfing better. :)
