Can't quite do it...
If you doubt ANY of the classical observations regarding sound at the macro level we need to deal with them one at a time. Because for each item you dismiss the yardstick becomes less accurate.
This is tricky. The Wiki article on sound says that the medium is oscillating. It even says that it's the exchange of potential and kinetic energy. I think we both agree that our speaker cone is oscillating. That is, it's moving back and forth.
But, is the air oscillating in the same way? The sound is moving through the air at Mach 1 and always outward from the disturber. If the air molecules are moving faster or slower but, still moving always outward, is the air "oscillating" or is it just changing speed?
Is there a
wave in the air that is moving an appreciable distance forward and back, in sympathy with the speaker. Or even a wave that is moving an appreciable distance forward and back but, relative to the Mach 1 speed that the sound is traveling?
You can put your measuring device into the sound field and observe that it oscillates in sympathy with the way the speaker cone did but, does that mean that the air itself was oscillating or does it just mean that there was a conversion from whatever the air was doing to the oscillatory motion of your measuring device.
We can get a clue about this from the despised,
Newton's Cradle toy. Do you see the intervening balls moving in sympathy with the ball you drop? You certainly see the end ball moving sypathetically. So, if the intervening balls don't noticably oscillate, or otherwise follow the motion of the fist ball, why would you believe that the intervening air, in a sound field, does?
These points (and others) are what I question about the way sound is classically described.
The problem with disagreeing with the classical definitions is that there's always an "out". There's nuances of menaing of terms. There's conditions under which the description can be made to agree. There are mathematical formulas that "prove" the classical defintions. There is the weight of the scientific commmunity saying that's the way it is so, that's what's accepted.
But, if the classical descriptions and definitions and math are so clear and unambiguous, how come there's so much confusion and misconception about how sound works even in an engineering community that rather prides itself on knowing how stuff works. There have been people, even in this thread, who have vowed that
air density and pressure affect the speed of sound...even after posts that specify that it doesn't.
So, when you say that I
must buy into
every aspect the classical presentation, I have to say that it has to do a better job of explaining it to
me before I do. I've generally been pretty happy with what I think has shaken out from this thread and I do believe it's helped to nail down some of the stuff that's not very clear in something like the Wiki descriptions (which I think we can both agree represent the "classical" view of sound).
