Will my chip fit in this device?...
gifford
Does this ... **broken link removed**
Fit in this...
and is the above just one of these ...
...but surface mount?
Also, is a DIL the same as a DIP, or a SIL a SIP?
someone correct me if i'm wrong:
DIL= dual in-line
DIP= dual in-line package
SIL= single in-line
SIP= single in-line package
ie- DIL/DIP and SIL/SIP are equivalents.
and yes that looks like a standard DIP socket, only surface mount. However you might have some trouble soldering it, since it doesn't have the normal "gull-wing" pins sticking out the side. Perhaps you should look for a more conventional surface-mount socket if possible...
that part should fit fine in it, as long as you get the standard 0.300 spacing socket.
DIL= dual in-line
SIL= single in-line
as suspected, cheers.
This would only be a problem if i was soldering them myself right? a manufacturer should have no problems?
Cant seem to find any! This is about the only company I have found that manufactures them (appart from tyco).
Aha thats what the 'standard' is, was wondering that.
