Its working now...
Did you learn anything?
Yes..
if 100 is 1024 so, 1 equal to 10.24..
please how to get all values between 1 to 100 conversion in ADC.
What? Is this a whole new topic?
Actually i am building wireless robot with speed control so, LCD on remote will tell the Total % speed of robot.
How do you get the speed of the robot using ADC? What kind of speed sensor you have?
I am not using encoder, just evaluating the potentiometer reading....
Just the % speed not eject..
How is it connected? How does it work? What is eject?
I will do it never mind.....the speed controller potentiometer will control speed and simultaneous the LCD will show the % of total/maximum speed of it can achieve..
#include <htc.h>
#include <stdlib.h>
__CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
#define _XTAL_FREQ 20000000
unsigned char inbuff[12]; // Transmision buffer
void HSerinit(void), HserinString(unsigned char*);
unsigned char Hserin(void); // transmission functions
int getInt(unsigned char* str); // a sort of atoi
void main(void)
int rxdata; // incomming data store
PR2 = 0b11111001 ;
T2CON = 0b00000100 ;
CCP1CON = 0b00111100;
ADCON1 = 0x6;
HSerinit();
TRISD=0X00;
unsigned char ch;
RD0=0;
RD1=0;
RD2=0;
RD3=0;
while(1)
RD0=1; // for testing hardware it is working till here..
RD1=0;
RD2=1;
RD3=0;
__delay_ms(502);
RD0=0;
RD1=1;
RD2=0;
RD3=1;
__delay_ms(502);
RD0=0;
RD1=0;
RD2=0;
RD3=0;
HserinString(inbuff); // get incomming data
rxdata = getInt(inbuff); // turn to decimal
CCPR1L = (unsigned char)rxdata ;// set PWM
ch=Hserin();
if(ch=='a'){
RD0=1;
RD1=0;
__delay_ms(2);
if(ch=='b'){
RD0=0;
RD1=1;
__delay_ms(2);
if(ch=='c'){
RD2=1;
RD3=0;
__delay_ms(2);
if(ch=='d'){
RD2=0;
RD3=1;
__delay_ms(2);
if(ch=='e'){
RD1=1;
RD3=1;
__delay_ms(2);
if(ch=='f'){
RD0=1;
RD2=1;
__delay_ms(2);
ch=0;
RD0=0;
RD1=0;
RD2=0;
RD3=0;
void HserinString(unsigned char* str)
int i = 0;
while(str[i++] != 0x0D) // wait for carriage return
str[i] = Hserin(); // get next character
int getInt(unsigned char* str) // sort of atoi
int result = 0;
while(*str !=0x0D) // until we see carriage return
if(*str >0x29 && *str < 0x3A) // Is it a number
result*=10;
result+= *str - 0x30; // convert to int
str++;
return result; // all done
while(!RCIF);
return RCREG;
void HSerinit(void)
TRISC = 0x80; // TX was an input!
SPBRG = 129; // 20Mhz xtal 9600 BAUD
TXSTA = 0x24; // TXEN and BRGH
RCSTA = 0x90; // SPEN and CREN
#include <htc.h>
#include <stdio.h>
#include <stdlib.h>
#define N 10
#define M 1
#define DATA PORTB
#define EN RC4
#define RS RC5
void LCDcmd(char x), LCDdata(char x);
void LCD_goto(char line, char column) ;
unsigned char outbuff[12];
void HSerinit(void), HseroutString(unsigned char* str), Hserout(unsigned char ch);
void LCD_printR(char *str);
unsigned char m[11]=" ROBO'91";
unsigned char z[17]="The Ultm Robotix";
unsigned char x[6]="Speed";
unsigned long number=0; // Number MUST be a long for fixed point
int ch=0;
unsigned char LCDbuffer[17];
void main(void)
TRISB=0X00;
TRISC=0X00;
TRISD=0b00001111;
__delay_ms(150);
LCDcmd(0x38); // init
__delay_ms(N);
__delay_ms(N);
LCDcmd(0x38); // Function set
__delay_ms(N);
LCDcmd(0x06); // Cursor move increase, no display shift
__delay_ms(N);
LCDcmd(0x0C); // Display on, cursor off, not blinking
__delay_ms(N);
LCDcmd(0x01); // Clear display. goto pos 1
__delay_ms(N);
unsigned char ch;
__delay_ms(150);
LCD_goto(1,2);
LCD_printR(m);
LCD_goto(2,0);
LCD_printR(z);
__delay_ms(3000);
int txdata; // data to transmit
TRISA = 0xff ;
HSerinit();
__delay_ms(100);
TRISA = 0xff ;
ADCON1=0b10000000; // Left justified
ADCON0=0b01000001;//000 = channel 0, (RA0/AN0)
ADIF=0;
ADIE=1;
PEIE=1;
while(1)
LCD_goto(1,4);
LCD_printR(m);
LCD_goto(2,0);
LCD_printR(x);
LCD_goto(2,6);
number = ReadADC();
number = number * 100 / 1024;
LCDbuffer[0]= (number / 1000)+ 48;
LCDbuffer[1] = 46;
LCDbuffer[2] = ((number % 1000) / 100)+ 48;
LCDbuffer[3] = ((number % 100) / 10)+ 48;
LCDbuffer[4] = (number % 10) + 48;
LCDbuffer[5] = 0;
LCD_printR(LCDbuffer);
number = number *5000 / 1023;
sprintf(LCDbuffer," %02d%%",number);
txdata = ReadADC(); // get analogue value on RA0
sprintf(outbuff,"%d\r",txdata); // convert to ascii text
HseroutString(outbuff); // send data
if((RD0==1)&&(RD1==0)&&(RD2==0)&&(RD3==0)){
ch='a';
Hserout( ch);
__delay_ms(2);
if((RD0==0)&&(RD1==1)&&(RD2==0)&&(RD3==0)){
ch='b';
Hserout( ch);
__delay_ms(2);
if((RD0==0)&&(RD1==0)&&(RD2==1)&&(RD3==0)){
ch='c';
Hserout( ch);
__delay_ms(2);
if((RD0==0)&&(RD1==0)&&(RD2==0)&&(RD3==1)){
ch='d';
Hserout( ch);
__delay_ms(2);
if((RD0==0)&&(RD1==1)&&(RD2==0)&&(RD3==1)){
ch='e';
Hserout( ch);
__delay_ms(2);
if((RD0==1)&&(RD1==0)&&(RD2==1)&&(RD3==0)){
ch='f';
Hserout( ch);
__delay_ms(2);
ch=0;
__delay_ms(5);
void LCDcmd(char x)
__delay_ms(N);
RS=0;
__delay_ms(M);
EN=1;
__delay_ms(M);
DATA = x; // Command data
__delay_ms(M);
EN=0;
__delay_ms(M);
void LCDdata(char x)
RS=1;
__delay_ms(M);
EN=1;
__delay_ms(M);
DATA = x; // Print data
__delay_ms(M);
EN=0;
__delay_ms(M);
void LCD_goto(char line, char column) // combines line and lineW
unsigned char data = 0x80; // default to 1
if(line == 2)data = 0xc0; // change to 2
data += column; // add in column
LCDcmd(data);
void LCD_printR(char * str) // This passes the start of a RAM character array
{ // by default the pointer points to data section
while(*str != 0) // while the character pointed to isn't 0
LCDdata(*str++); // print out the character, then increment
void HSerinit()
int ReadADC()
int ret = 0;
__delay_ms(10);
GO_DONE = 1; // start conversion
while(GO_DONE); // wait for conversion
ret = (ADRESH & 0x3) << 8; // get
ret += ADRESL; // result
return ret;
void HseroutString(unsigned char* str)
while(*str != 0) // while all transmitted
Hserout(*str++);
void Hserout(unsigned char ch)
while(!TXIF);
TXREG = ch;
