D Dougcrf New Member Mar 2, 2009 #1 would a 3.0VDC 1.0A work in place of a 3.0VDC 1.6A as a charger, it is being used for a hair cliper. Thanks, Doug
microtexan New Member Mar 2, 2009 #2 transformer Assuming you'll be using the rest of the original charging circuit, all should be fine. Last edited: Mar 2, 2009
ecerfoglio New Member Mar 3, 2009 #4 Dougcrf said: would a 3.0VDC 1.0A work in place of a 3.0VDC 1.6A as a charger, it is being used for a hair cliper. Thanks, Doug Click to expand... Your old supply is rated at 1.6 A, and your new transformer is rated at 1.0 A. It may work if your hair cliper uses 1.0 A or less, but if you can you should get another one with a rating of 1.6 A or more
