I usually use an external high speed rect in parallel with the internal one, source to drain.
Also http://www.irf.com/technical-info/appnotes/an-936.pdf
Max.
Max.
Max.
Ok. Thanks1. No, unless it is push pull.. the diode goes across the inductive load in reverse of normal direction, rated for same current and forms a smaller current loop.
2. No, unless just used at low rates as all diodes have capacitance.
Depending on speed diode must be a fast recovery type Schottky. The normal Body diode unless a zener does not protect for overvoltage because the diode is in reverse connected to Drain instead of V+ for low side switch.
Push-pull means complementary or half bridge driver.Ok. Thanks
But for question 1, you said no "unless its push pull..."
So how do I place the diode in push pull cos I do push pull application for people?.
And I play around sometimes
Also it has to be a zener right or will an ordinary diode do in this configuration..
Then you would still need a zener if bipolar or diode across coil to V+ , if unipolar for fast low side turn-off +ve transients.. Right?I use mine on a full bridge.
Max.
Yes I know but what I was asking was how do I place diode for MOSFET protection in push-pull application.Push-pull means complementary or half bridge driver.
