It has only a couple of tuned circuits and the values of the capacitors and inductors are specified. They will have a very wide bandwidth and the accurate frequency is determined by the quartz crystal.bananasiong said:then i have to use a trimmer cap for the tank circuit?
This is UHF isn't it? It is nearly microwaves. Everything affects a tuned circuit at such a high frequency.EDIT: Does the amount of the solder affect the stray capacitance or the frequency?
bananasiong said:Oh.. then i have to make sure both the transmitter and receiver to be the same. So difficult..
bananasiong said:Why should it be as thin as possible?
I always use soldering paste/flux. But what's the purpose of using it? Easier to remove the solder?
When soldering, I'm always facing this problem: some oil (or whatever that I don't know) left on the PCB after soldering and removing the components for a few times that makes the solder not to stick on the PCB.
If I use UV PCB, should I remove the film after etching?
