Accurate 5-digit digital ammeter module
electronium
Greetings to the colleagues of the forum
Be sure to get this accurate 5-digit digital ammeter module for your work. It is very effective. You can meas
It worked very well for me... the amount of charging amperes, types of batteries, amperes, smd led chips, power supply, sensitive and accurate, it
really works.
do you have a question here? Or is this just an endorsement of a product, an endorsement of a technology or an advertisement?
To me, it looks like a Vellman style meter that typically have trouble with three digits of accuracy because they do not use zero temp coefficient burden resistors or compensate for temp in any way.
It is not an advertisement of a product, because I did not mention the name of a specific company, it is only a suggestion and confirmation of a product, which is considered an important tool for accurate work.
Now the question is, can the amperage be increased to 10 amps? how is it possible?
Now the question is, can the amperage measurement be increased to 10A? How is it possible?
Do the traces on the circuitboard inside the unit look like they can handle 10A? If not, the answer is no.
You would have to modify the shunt, and rewrite the code for the
G factor of the shunt to get correct display. Or if not a processor
look at datasheet for measurement IC to see how range is handled.
Regards, Dana.
really works.
And just how accurate is it?
What is the products accuracy specification? What does it use as it's internal reference? How stable is that reference's initial accuracy vs. it's drift over time and temperature?
Please be aware that having many digits of display may give you fine resolution, but not necessarily fine accuracy.
Taidacent Blue Color High Precision 5 Digit Amp Meter DC 0.0000-3.0000A Ammeter Digital Display DC Digital Ammeter Resolution 0.1mA​
RangeDC0-3.0000A, the maximum reservation can be measured 5A, the accuracy above 3A has a slight impact
Display5 digit 0.36 inch LED
Digital tube display colorRed / Blue can be optional
Refresh rate>3 times per second
Measurement accuracy± (0.5 ‰ + 2 words) (meaning that the maximum error of the table is within 1.7mA, the normal error is less than 0.5mA)
Supply voltageDC3.5-30V
Working temperature-10 ° C ~ 65 ° C
Opening size45.5mm*26.5mm (the opening directly snaps the watch into the panel)
Dimensions48mm*29mm*21mm
Temperature coefficientless than 50PPM / °C
Special attentionPlease follow the instructions carefully, otherwise the consequences of burning will be conceited
  1. Taidacent Blue Color High Precision 5 Digit Amp Meter DC 0.0000-3.0000A Ammeter Digital Display DC Digital Ammeter Resolution 0.1mA
