Audio splitter troubles
moody07747
today i built an audio splitter
the input is a 1/4" phone jack and a 1/8" phone jack
the output is three 1/4" phone jacks and two 1/8" phone jacks
everything is wires inside the case, no circuit board
a few minutes ago i swapped out some of the mono connectors with sterio connectors because i wanted sterio sound
anyways
i pluged my MP3 player and electronic drum set into the input and my headset into the output. When i turned on the MP3 player it sounded great but there was some static type noise. after that i turned on the drum set and set it to vol. 5 which is normally loud but when patched through my audio splitter it was really quiet. even at max. volume the drum set sound quiet.
so why is the splitter making my drum set quiet and why is there that static type noise from the MP3 player?
ill be resoldering everything tomarrow after i get some fuel for my soldering torch
it kept going out when i was soldering the mono to sterio connectors
maby theres a bad connection in there
oh, heres the wireing sheet for my splitter (see pic)
You can't just short the two inputs together!, it means you're shorting the output of your drum machine and MP3 player together - this will make them both quiet, and could potentially damage them.
What you should do is build a virtual earth mixer and mix them together!.
ok
ive been searching the net today and have been to many sites searching for a "virtual earth mixer"
here are a list of sites i found that i think will work
(this first one looks like it will work and seems easy
i would just take out one of the mic inputs
these next two pages just confused me...allot
http://www.all-electric.com/schematic/simp_mix.htm
so thats what i found and overall i like the first page
there is no part list for this so i do have a few question that you guys might me able to help me out with
those small green boxes are resistors, right?
what are the green boxes labled "10k log, POTs?
and what are the circles by those 10k log things?
thanks
im hoping someone knows all this, someone should because i found this page throught this site
Yes, it's the internationally agreed symbol for resistors (although not green!), and has been for probably 40 years?.
Volume controls.
I presume it shows the ground connection of the volume pots.
Since you don't have microphones, you need only the single opamp at the right side of your 1st link.
The TL082 is a dual opamp, you need only half of it for mono or make a stereo mixer with dual volume controls.
thanks for the info
ill probably wire the audio splitter backwards so i have 5 inputs and 2 outputs
ill pick up those parts when i get some time
ive been buzy wiring my house with a 220 volt outlet for my new welder...i couldnt resist the blue color of the millermatic 175 :roll:
Hi Moody,
Your 5-input mixer circuit looks very good. Where's the 2nd output?
16 guage wire can carry about 12A. The current in this project is just a couple if mA so 24 guage wire is fine. :lol:
I plan on building this in a metal case so i can just attach all the ground to the metal case
the wiring shows one output and i think thats all i need
ive been trying to figure out how to wire the output of this
the wiring sheet shows one wire for output...im confused by this
i want to attach 2 binding posts that will hold the wire going to the speaker but how do i do that with one wire?
is the pos. (+) the one they show and i just ground off the negive?
allong with the posts, i would like to have a 1/4" audio phone jack (sterio) so i can plug headphones into the output
as i said, that output is really confusing me
with a few questions i shouls be able to get this project done
im not too good at electronics now but the more i do these the better i get
i just need some taining on reading wiring sheets
The schematic clearly shows two 9V batteries. One for the opamp's +V supply and the other for the opamp's -V supply. Where the batteries connect together is connected to the input ground, the output ground and the opamp's input ground.
You can't ground off the negative or you will short the negative battery and the opamp won't work.
ok now im really confused, so confused that im getting ready to pay someone here $20 to build this thing for me :lol: (could be because its 1:30 am)
i have to feed this into a amp to run a speaker?
no problem, i can always build an 8 watt amp or something
does this put out mono or sterio sound?
will this chip work?
https://www.jameco.com/webapp/wcs/s...toreId=10001&catalogId=10001&productId=213137
if not, heres the list i have to pick from
moody07747 said:
that would be four 9 volts are needed correct?
No. One mono circuit needs +9V and -9V. A stereo or even a 4-channel circuit still needs only +9V and -9V.
A power supply can power as many circuits as its current rating allows.
This circuit will draw a whopping 2mA from each supply for each channel.
It doesn't have to be 9V. It will work fine with+6V and -6V, +12V and -12V or +15V and -15V. :lol:
