Danwvw
Active Member
Could use some help to design a 2 or 3 Transistor voltage regulator for my 6 volt automotive generator.
Given 7 Volt 45 Amp Bosch B circuit Generator,
1000 AH AGM 6 volt Battery, (Ideal charge voltage 7 volts)
Full Load with 2X H4 High Beam 65Watt 6 volt headlights and brake lights and ignition sys is somewhere below 180Watts,
Field current?
Field Winding measures 1 ohm of resistance,
Field Voltage about .8 volts when generator is charging the battery at 7 volts.
I have seen some schematics for 12 volt A circuit ones but none for 6 volt B circuit generators.
Note the B circuit generator has the other end of the field coil connected to the D+ which is + output of the armature. I will post a equivalent schematic once I figure out how.
One additional thing Is that I think the design will need to use a old fashion PNP 20-50 amp low gain power transistor for the driver it could be nicely mounted to a grounded heat sink with it's emitter connected to the field and it's base to the rest of the circuit which would regulate voltage (7V) and current (25A) of the generator.
Thanks.
Field current?
Thanks.
