Consulting on my next project
Thank you NorthGuy :)
Are you sure about having Head always larger than Tail?
At some point, Head will "overflow" and will start counting from 0 again, while Tail is yet to overflow and therefore be larger than Head, right?
If they're 32-bit numbers, they only overflow at 4294967296, but if they do overflow, it doesn't really matter. You simply define Size as unsigned int.
C:
unsigned int Size;
Size = Head - Tail;
If Tail is 0xffffff80 and Head overflowed to 0x10, the difference will be calculated correctly as 0x90.
Hi again NorthGuy.
Thank you friend :)
If Size is unsigned int.
Lets take the case where there were (2^32 + 100) bytes written, so
Head = 100
And say that
Tail = 4294967196 (which is 2^32 - 100)
e.g. Size should be 200.
Size = Head - Tail = 100 - 4294967196 = -4294967096
Does it really turn out to be 200?
