Mosaic
I etch with dilute nitric about 3:1 mixdown from fuming HNO3. I like it because it's clear, doesn't stain and skin can tolerate it for up to 15 seconds with no irritation. Ask me how I know...been using it 30 years now.![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So rather than dumping the solution when it gets dark blue and slows etching...I decided to reconstitute the nitric acid by electroplating the copper out.
Using graphite plates I proceeded to execute this idea...it worked for a while (@ 3A/sq in current density) with good agitation from oxygen production on the anode until the solution heated up due to current flow...then the plated copper dissolved back into the solution at around 40°C.
So temperature accelerates the etching and defeats the plating.![banghead :banghead: :banghead:](/styles/default/xenforo/smilies/banghead.png)
Trying to plate with low currents probably won't work too well as the etch vs plating balance would be found quickly and plateau out.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So phase 2. Place the electroplating cell in the freezer
(I have a workshop fridge for preserving acrylic glue, PVC cement, solder paste etc), and try again...
