Hi MrAl,
I've run the simulation. Voltage across R2 is approximately 5.25 volts and current is about 52.5 mA.
hi Squire,
Your sim runs OK, I would recommend that you reduce the Base resistor from 10K to say 1K.
Sir K.![]()
SORRY. Many years ago (about 53 years ago) I also had NO knowledge of electronics (but I was very involved with nice young ladys). Then I learned about electronics.
I played with many nice voung ladies then I married the nicest (sexiest) one! Now I have 3 grown up kids and I am a grandfather.Then...what happened to the nice young ladies after you learned about electronics?![]()
Hi again,
3 or 4ma sounds pretty good, maybe 5ma optimum, have to read the zener spec sheet.
I did a few runs myself and found that as the resistor gets larger one of the interesting things is that since the gain of the transistor is (somewhat) fixed, the lower current means less emitter current which means the output cap charges slower which in turn means the startup takes longer. With 1k under 1us, but with 10k up to 5us startup time. Startup time here is defined as the time it takes the output to ramp up to the final output voltage from zero volts.
What you should check:
First reduce your max step time to 1e-8.
Check the model of the transistor see that Bf is equal to 300.
Check the model of the zener see that the capacitance is less than 200pf.
Check the version number of your LT Spice simulator software, see that it is 4.15w or better (Help/About LT Spice).
alec_t
Have you got the sim command set to 'Start external DC supply voltages at 0V' ? If so, that slows the rise time.
I did what is stated above sir.
Bf is 300. Capacitance for the zener is 185pf.
I am using 4.15w.
I am getting the same waveform as before.
Yes, I checked the box containing 'Start external DC supply voltages at 0V'.
Here's my simulation.
