DerStrom8
Super Moderator
should be reserved for electrolytic (i.e., polarized) capacitors.
Keep in mind that not all electrolytic capacitors are polarized...
Regarding that, the capacitor with the curved bottom should only be used for electrolytics
Farenheit has better resolution through the comfort zone of 68F (20C) to 80F (26.66).
I hate decimals in environmental temperature.
Yes. One degree Celsius (I believe that's how his name was spelled) is a rather large minimum setting resolution for an indoor thermostat. It should be no greater than about 0.5 degree celsius (or one degree Fahrenheit) to achieve a comfortable setting point.........
Thanks Ron, saved me some typing.
I may add, I don't like some schematic backgrounds
eg: black, heavy black Grid dots.
Drawings where the connecting lines are like a spiders web, criss crossing at all angles.
Regarding symbols and values text, I don't mind which convention is used
I agree. Fahrenheit forever!
Just to add some more: Besides criss crossing I don't like nets drawn through components like microcontrollers and connectors. Any component area is a "no-go-area".
I've been using nF for those values in between µF and pF for a long time. Was actually surprised to start seeing others do that in published stuff as well.
I don't think it's totally weak. To display roughly the same resolution with a digital thermometer at room temperature requires 3 digits with Celsius and 2 digits with Fahrenheit. For consumer applications, such as home thermostats, that can be a significant cost factor.......................
That's a weak argument about the granularity of the scale. I have digital thermometers all over the house and workshop and all have reading to xx.x'C. Electronic components are usually rated "-40'C to +85'C" and you can see at a glance how much below freezing or how close to boiling point the values are.
Boncuk:
Absolute 0 = 273 C;
Pascals for pressure 26 PSI is 179,263.68928 Pascals
How would you like to inflate your car tires to: 179,263.68928 Pascals
Talk about Yuk!
That's because hardly anybody in the USA knows what a bar is (other then the kind that serves alcoholic drinks).If you stop at any gas station in Germany to check the tire pressure it's very easy. The pressure gauges indicate bar and PSI. I haven't seen one gas station having that kind of "service" in the USA.![]()
With a positive value at the freezing point of water? (32deg/F)
Crap!
