Yes but it is not used.
Well, duh. We already know that.
Or what about the relationship between 'C:watts? Surely that's worth a lot in electronics.
Still no relationship; why do you keep supposing there is one? The choice of temp. measurement system (C or F or K or ...) is completely arbitrary.carbonzit said:Well, duh. We already know that.
4pyros said:OK than thats the answer to this;
Unless you can show that there's some fundamental physical or mathematical relationship between °C and watts, just accept that it's that way because it's that way.
There is this formula which indirectly relates watts to degrees, it just requires some other variables as well:
ΔQ = mcΔT
Where Q is the energy in Joules (converted from watts--again, a few other variables are needed), m is the mass, c is the "specific heat" (amount of heat required to raise the temperature of a material by one unit of temperature, relative to another material) of the substance that is being heated, and T is the temperature in Celsius. And of course, Δ is 'delta', meaning 'change'.
Butbutbut ... if you change your "c", it'll work just as well for Fahrenheit as for Celsius. So there's still no natural connection of any kind between °C and W.
Heat sinks are rated by their thermal resistance (Rth) in °C/W.
BobScott said:If you don't like a particular convention, don't gripe about it. Nobody likes listening to a whiner.
Fahrenheit is not really a proper scientific unit for working with temperature it's a "consumer unit", and only in a couple of countries that haven't quite caught up yet.![]()
So just how is Celsius a more "scientific" scale than Fahrenheit?
Oh, gosh, it must be ... because 0°C is the freezing and 100°C the boiling point of water. That's soooo scientifical.
Isn't that just as anthropocentric as how all the SI-pushers claim the inch and foot are so ridiculous, since they're based on the size of the king's thumb and foot?
Regarding that, the capacitor with the curved bottom should only be used for electrolytics:
is for non-electrolytics, and
should be reserved for electrolytic (i.e., polarized) capacitors.
Your answer is a typical fallacy used in argument. I don't know the exact name of it, but it's basically arguing that since more people adhere to proposition X than proposition Y, proposition X must be correct.
Actually, the chart itself is a fallacy (and if you don't believe me, I invite you to read any of Edward Tufte's works, like his definitive The Visual Display of Quantitative Information). What does the variation in the units that compose a measure have to do with anything? This is just BS tarted up in a chart to make it look authoritative.
Nobody uses yards to a mile. Therefore, we can eliminate the number 1760 from contention.
That leaves the numbers 3, 12, and 16. Anyone who can't remember these simple numbers and how they relate to measurements is an idiot anyhow. So no, we don't need the crutch of a system where everything is based on 10.
Mr RB said:Fahrenheit is not really a proper scientific unit for working with temperature it's a "consumer unit", and only in a couple of countries that haven't quite caught up yet.
