bananasiong
I didn't know about this fuse, I've just googled it. Is it added between the stepped down voltage and the rectifier? Does polyfuse have any value?
This sounds like AM? Not frequency modulation right?audioguru said:Yes. The audio signal at its base amplitude modulates it which causes its collector voltage to increase and decrease with the audio. The changing of the collector to emitter voltage changes its capacitance so changes its frequency.
If the output is shorted then the LM317 limits the current to about 2.2A. If it gets too hot then it shuts down to protect itself.bananasiong said:If it is shorted for 1 second, it won't blow right? Then will I blow the LM317 or the transformer?
So what current rating should be used?
These simple FM oscillators produce a little amount of AM and a lot of FM at the same time. A good radio's FM detector rejects the AM.This sounds like AM? Not frequency modulation right?
bananasiong said:I'm using a 3VA transformer, I don't know whether I can get the polyfuse or not, I've never heard it before. Any heatsink required fot the polyfuse?
https://en.wikipedia.org/wiki/Polyfusebananasiong said:PTC, is it found in some temperature control circuit? I didn't know that it is applicable in this function also. I thought it is just burned and increase the resistance, then beeping comes from the speaker![]()
Use a character selector.bananasiong said:How do you make the square (2) ?
bananasiong said:The tank circuit at the output side is to peak the output power, is it the same for all frequency? Or I need to tune it to the peak for different frequency using oscilloscope to see the amplitude?
bananasiong said:If I use oscilloscope to view the output waveform, and tune until the highest amplitude, can I get the same result? Since it is quite difficult to count the frequency at around 100MHz.
No, only 100MHz maximum CRO is available for me.Nigel Goodwin said:Do you have a 200+MHz scope?.
Yes, you told me to add another small wire next to the antenna for the probe or else the transmission will be affected.audioguru said:Don't connect your 'scope to the transmitter's antenna. The input capacitance of the 'scope will change the frequency of the tuned circuit.
A 5Hero999 said:Not if you use a 5ohm piece of coaxial cable and connect a 50
hm: resistor across the scope input to mach the impedance of the cable.
That was a typo, I meant 50bananasiong said:A 5hm: coaxial cable? Do you mean the resistance of the probe?
Most scopes have a 1Mbananasiong said:Touch a 50hm: from the antenna to ground when measuring by CRO?
