Thunderchild said:no I meant you have a solar power station but instead of storing it in batteries directly use it to split water into H and O2
You're missing the point! - solar cells are VERY inefficient, you would need a large area to produce enough hydrogen to run a single car.
these can then be fed into cars at a fuel pump, many cars run on methane gas what's wrong with using hydrogen instead ? it is the same as methane without the polluting carbon that makes up good part of the weight CH4, carbon is a much heavier element than Hydrogen so methane is not as efficient as hydrogen. So if we already use gas propelled cars what wrong with changing gas ?
Hydrogen is FAR more dangerous - and as it stands, gas powered cars are more dangerous than petrol ones.
Splitting water to produce hydrogen, then burning it, isn't efficient either - why not use the original solar power to charge batteries?.
