Full Bridge Rectify an audio signal?
I'm working on a project that turns on LED's with low frequencies.
I'm switching a FET with the positive alternation. However, this is only giving me 50% duty cycle. I was thinking of putting a full bridge rectifier before the FET to produce a near %100 duty cycle.
Is this possible? If so, where am I connecting the inputs of the rectifier?
Here is a picture of a rectifier to reference diode junctions.
Here is a link to op amp rectifiers. That is probably the way to go.
A full-wave bridge rectifier requires an isolated source (such as the transformer shown) which I assume you do not have.
One way to full-wave rectify an audio signal is to use a precision rectifier (see figures 4, 5, and 6). Those circuits also have the advantage of essentially canceling the forward drop of the diodes.
Edit: ronv, you beat me my a few minutes.
Awesome, thanks. The hollow triangle on the bottom of those circuits that aren't connected to anything are ground, correct?
